Virpie Tech
Last activity: 12 Dec 2019 13:30 EST
Prevent checkin the flow in draft mode in Dev or to enable QA environments to throw exceptions
We would like to prevent the developers from check-in the flow in draft mode in Dev Environments or to enable QA environments to through exceptions on DRAFT on flows
We are using PEGA PRPC 7.1.8 , Is there any hotfix or workaround available to handle this issue
***Edited by Moderator: Lochan to update platform capability tags; add SR tag***
