Please reset the password of [email protected] (Related to INC-249596)
This is related to resolutions provided for INC-249596
Summarizing activities done:
- Followed instructions from the video shared by Pega
	- Zip file used was the file shared by Martin
- Run a command from command prompt
	- prpcUtils.sh import
- after running, the following error was encountered
… [echo] /root/Pega/116867_Pega8.51/scripts/utils/prpcUtilsWrapper.xml:137: The following error occurred while executing this line:
[echo] /root/Pega/116867_Pega8.51/scripts/utils/prpcUtils.xml:447: Unable to load driver class from the following path(s): C:/users/path/to/driver/ojdbc6.jar
… [echo] Caused by: /root/Pega/116867_Pega8.51/scripts/utils/prpcUtils.xml:447: Unable to load driver class from the following path(s): C:/users/path/to/driver/ojdbc6.jar
1. script provided so you can replicate
2. scripts used and results
