PegaRULES server not available - while accessing url
Getting PegaRULES server not available in the browser while accessing application. Can anyone help us in fixing this?.
I guess you already tried to restart and it's still failing, right?
if yes, then without the logs it will be difficult...
you could also add PEGA version, DB/Application server type
Regards
Anthony
"PegaRULES server not available" - is it EXACTLY what you see on the screen? Could you please attach a screenshot?
Can you share any log?
Hi Razan,
Please find the below URL which might be helpful for this issue.
From how long you are getting this error.Did you do any deployment before that.Can you please let me know error present in logs.
Abhinav
Pega Support Center has detected you are using a browser which may prevent you from experiencing the site as intended. To improve your experience, please update your browser.
