WTS Advisory
DE
Last activity: 16 Feb 2016 18:52 EST
HTTP Status 503 - PegaRULES server not available
Hello everyone,
i just successfully finished the Pega719-postgresql9.3-tomcat 8. But when i try to access the /prweb/PRServlet after deploy of war file, it gives me error "503-PegaRULES server not available".
- pgAdmin has the Satistics of "select pzlastmodified, pzbinarycontent from rulesschema.pr_engineclasses......."
- tomcat/app manager says "OK - Started application at context path /prweb"
- Already tried to reinstall Pega. Problem still exists.
Don't know what to do next, need help....Below are the logs:
2016-02-16 16:04:16,289 [ALDECLARATIVECLASSES] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..starting
2016-02-16 16:04:16,289 [ALDECLARATIVECLASSES] [ STANDARD] [ ] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Starting global declarative cache pre-load...
2016-02-16 16:04:16,351 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load pegaConclusions ..starting
2016-02-16 16:04:16,944 [LOAD_PEGACONCLUSIONS] [ STANDARD] [ ] [ ] (dictionary.ConclusionCacheImpl) INFO - Starting conclusion pre-load...
2016-02-16 16:04:18,005 [ FRCVASR1892] [ STANDARD] [ ] [ ] (c.DependentRuleSetListPoolImpl) INFO - Loaded 1681 ruleset dependencies
2016-02-16 16:04:18,036 [ FRCVASR1892] [ STANDARD] [ ] [ ] (ternal.vtable.VirtualTableImpl) INFO - Virtual Table Preload Starting...
2016-02-16 16:04:18,083 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..starting
2016-02-16 16:04:18,083 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - Start AppCentric reloadCache processing for node 09b2ea68dfdb41c879d276fbfe9b0330. Maximum age in hours for Usage data is 96. Maximum rows to load is 14400
2016-02-16 16:04:18,192 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - End of reload processing, loaded 0 rows, elapsed time is 109 milliseconds.
2016-02-16 16:04:18,192 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] [ ] (pcentric.RACacheAppCentricImpl) INFO - reload added 0 assembledClasses 0 shortcuts.
2016-02-16 16:04:18,192 [l LOAD_ASSEMBLYCACHE] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load reloadCache ..done
2016-02-16 16:04:29,549 [ FRCVASR1892] [ STANDARD] [ ] [ ] ( internal.mgmt.PREnvironment) ERROR - com.pega.pegarules.pub.PRRuntimeException: Method Invocation exception
2016-02-16 16:04:29,830 [ FRCVASR1892] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) ERROR - PegaRULES initialization failed. Server: FRCVASR1892
com.pega.pegarules.pub.context.InitializationFailedError: PRNodeImpl init failed
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:390)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.getThreadAndInitialize(PRSessionProviderImpl.java:1998)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineStartup.initEngine(EngineStartup.java:664)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._initEngine_privact(EngineImpl.java:165)
at com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.doStartup(EngineImpl.java:138)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener._contextInitialized_privact(WebAppLifeCycleListener.java:311)
at com.pega.pegarules.web.servlet.WebAppLifeCycleListener.contextInitialized(WebAppLifeCycleListener.java:218)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:497)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:370)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:411)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
at com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4812)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5255)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployDirectory(HostConfig.java:1091)
at org.apache.catalina.startup.HostConfig$DeployDirectory.run(HostConfig.java:1830)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: com.pega.pegarules.pub.PRRuntimeException: Method Invocation exception
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1272)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
at com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.getThreadAndInitialize(PREnvironment.java:382)
... 28 more
Caused by: java.lang.reflect.InvocationTargetException
at com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
... 31 more
Caused by: java.lang.OutOfMemoryError: GC overhead limit exceeded
at java.util.HashMap.newNode(HashMap.java:1734)
at java.util.HashMap.putVal(HashMap.java:641)
at java.util.HashMap.put(HashMap.java:611)
at com.pega.pegarules.pub.util.HashStringMap.putString(HashStringMap.java:168)
at com.pega.pegarules.data.internal.access.PageDatabaseMapperImpl.setResultStringFromResultSet(PageDatabaseMapperImpl.java:849)
at com.pega.pegarules.data.internal.access.ResultSetIteratorImpl.getPage(ResultSetIteratorImpl.java:332)
at com.pega.pegarules.data.internal.access.ResultSetIteratorImpl.next(ResultSetIteratorImpl.java:252)
at com.pega.pegarules.generation.internal.vtable.dao.AbstractVirtualTableCacheQuery$ResultSetReader.next(AbstractVirtualTableCacheQuery.java:350)
at com.pega.pegarules.generation.internal.vtable.dao.AbstractVirtualTableQueryProcessor.process(AbstractVirtualTableQueryProcessor.java:66)
at com.pega.pegarules.generation.internal.vtable.dao.AbstractVirtualTableCacheQuery.query(AbstractVirtualTableCacheQuery.java:216)
at com.pega.pegarules.generation.internal.vtable.dao.VirtualTableDataAccessObject.loadTable(VirtualTableDataAccessObject.java:74)
at com.pega.pegarules.generation.internal.vtable.VirtualTableImpl.init(VirtualTableImpl.java:172)
at com.pega.pegarules.generation.internal.PRGenProviderImpl.finishInit(PRGenProviderImpl.java:658)
at com.pega.pegarules.session.internal.mgmt.PREnvironment.finishInit(PREnvironment.java:525)
2016-02-16 16:04:29,830 [ FRCVASR1892] [ STANDARD] [ ] [ ] ( etier.impl.EngineStartup) INFO - PegaRULES initialization failed. Server: FRCVASR1892
2016-02-16 16:04:29,955 [ FRCVASR1892] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) ERROR - Enterprise tier failed to initialize properly, PegaRULES not available
2016-02-16 16:04:29,970 [ FRCVASR1892] [ STANDARD] [ ] [ ] (ervlet.WebAppLifeCycleListener) INFO - Web Tier initialization is complete.
2016-02-16 16:05:15,323 [ALDECLARATIVECLASSES] [ STANDARD] [ ] [ ] (bi.DeclarativeCacheManagerImpl) INFO - Loaded 3844 global declarative cache instances
2016-02-16 16:05:15,323 [ALDECLARATIVECLASSES] [ STANDARD] [ ] [ ] ( external.async.IStartupTask) INFO - load global declarative classes ..done
