PEGA0001 Alerts Generated By ReloadSection & ReloadHarness Rules
Show More
Show Less
Can you check into here: https://community.pega.com/knowledgebase/articles/pega0001-alert-http-interaction-time-exceeds-limit
Pega0001 comes if the HTML page takes more than the set threshold time to load.
Please verify if you are getting any pega0005 or pega0020 alert as these are performance alerts.
You will need to fine-tune your database and also look for any forms embedded within a form and making the section longer to load in the expected time.
Try to find out the pattern and resolve the root alert.
