Can ParameterPage values be supressed for PEGA0001 alert log entries?
Occasionally, I see PEGA0001 entries in our alert logs when users perform long running operations with word documents (PROpenAuthoring ActiveX). Unfortunately the log entries contain the parameter page for the running activity at the time; this has a FileSource parameter which contains the Base64 encoded document returned by the ActiveX control, this is often quite large and causes the alert logs to bloat massively, as well as causing problems with AES.
I know we can supress parameter pages in PEGA0002 - PEGA0007 events.
Is there a way to supress the parameter page for PEGA0001 events in the alert log? Ideas and advice appreciated.
Cheers!
***Updated by moderator: Lochan - User still needing assistance. Adding #helpme tag***
SR-A88690 Created
***Updated by Moderator: Marissa - Added SR to post***
