Pega Robotics Studio 8 debug issue
After installing the Robotics Studio following the steps in "Pega Robotic Automation Studio 8.0 Installations Instructions" document, facing an issue in debugging a solution. Whenever click on "Start' button or press "F5" or select "Start Debugging" from Debug menu, studio is unable to run the solution.
It seems that the Robotic Studio is not running properly even after debugging(F5) as highlighted in the attached screen. But the build successful message appears. Uninstalled the Robotics Studio and Visual Studio several times and reinstalled but still the issue exists. Any idea on what could be the reason?
Thanks in advance.
***Updated by moderator: Lochan to update SR details***
Hello!
On reviewing the SR, we see that the issue was resolved after updating the application to the latest 8.0 build.
