Accenture Solutions Pvt Ltd
Last activity: 18 May 2018 17:52 EDT
Pega Robotics Automation not working when Set HideApplicationAtRuntime to True for Java Swing Desktop application
Hi
When Enabled HideApplicationAtRuntime to True & while trying to run the OpenSpan solution (using Windows adapter on java desktop application) in v8.0.1080 ,automation is getting failed in middle of the designed flow & failing & stooping when performing some actions to identify few controls (javax.swing.panel) where as the same Solution is working fine When HideApplicationAtRuntime is set to false. What could be the issue? Please guide.
Pravallika.
