Getting Incorrect Result for Calculator Application using Robotics Desktop Automation
I have integrated RDA with Pega 722 and trying to automate the Calculator Application to Perform sum of two numbers(6+4) and return the result to Pega. But Getting incorrect results like 6 or 4 to Pega.
The result always generated correctly in Calculator Result box but the value which is coming to Pega is not correct. I'm thinking may be my Automation flow is need to be corrected.Please Find the attached automation flow.
Thanks...!
