StepChange
Last activity: 21 Jun 2023 10:56 EDT
Pega Robotic Automation API
Pega Robotic Automation™ can support Pega Platform™ by automating front-end applications without accessible Pega Platform channels by using the right tool for the right time. For example, if an application has an API, Pega Platform can access the application API. If the application does not have an API, then Pega Robotic Automation can access the application for use in the case life cycle.
Above is taken from Pega academy.
I just want to understand.
Are they saying If an application on the Pega platfrom has an API it can not be used by Pega RPA? but if the app does not have an API its open for use by Pega RPA?
Way it was worded is hard to understand can anyone shed some clarity on this.
