ING Belgium SA NV
BE
Last activity: 1 Jun 2018 12:18 EDT
Pega Platform 7.31 compatibilite with pega marketing 7.13?
Please confirm if Pega Platform 7.31 compatibility with pega marketing 7.13?
Updated: 1 Jun 2018 6:06 EDT
Hello!
Thanks for posting on PSC.
Pega Marketing 7.31 can be installed on Pega 7.3.1. Please refer the Pega Marketing 7.31 Installation Guide here > Prerequisites section: https://docs-previous.pega.com/pega-marketing-731-installation-guide
You can find all documentation on Pega Marketing 7.31 here: Release Information & Product Guides
Also, for your reference: Pega Marketing page on PDN
ING Belgium SA NV
BE
Hi Lochan,
posted this for compatibility between Pega 7.3.1 and PM 7.13. not about pega marketing 7.31.
Please advise
Sorry!
Here's the link to the installation guide of Pega Marketing 7.13: https://docs-previous.pega.com/pega-marketing-713-installation-guide
The Prerequisites states this:
- Pega 7.1.9 or higher is installed and verified.
- The highest Pega 7 Ruleset Version is 07-10-99
I shall however, get you a clearer answer through a Pega Marketing SME.
That combination is not supported. You will need to upgrade Pega Marketing 7.31.
Raghu
ING Belgium SA NV
BE
Thanks for the info. We recently upgraded to pega 7.31 and we are in PM version 7.13 now. we should upgrade it to PM 7.22 prior to PM7.31.
The problem\issue(not real problem) that we are facing now is we could not open any marketing(rule no longer exist) rule(PM 7.13) after pega 7.31 upgrade?
shall we expect this issue(rule no longer exist) will be resolved after migrating PM 7.22 ? or it would be resolved only after PM 7.31
It is best that you investigate why marketing rules are not visible before the next upgrade because if the application can't see rules, it will likely not upgrade them. Reasons its not seeing rules is potentially because application stack/ruleset versions are not correct so review that.
ING Belgium SA NV
BE
Hi Saleem,
I will explain the scenario of our application now.
Our application was using pega 7.1.9 and PM 7.13. We upgraded pega to pega 7.31 and were checking the marketing rules(treatment,output DBtemplates) if all looks good.
And, we found that some of marketing rules were not opening(rule - no longer exist). so, we suspect that pega 7.31 with PM 7.31.
is it an issue to be addressed or we can proceed with PM 7.22 and followed by 7.31 and rules will work after PM 7.31?
