Tata Consultancy Services
Last activity: 26 Feb 2024 7:36 EST
Pega performance affected due to ADM,RTDG and Realtime(inbound)
we have the following node configuration :
6 nodes for batch,backgroud ,custom1,custom2,search
4 nodes for RTDG,ADM and Realtime(Inbound)
1 search node
2 stream node.
1 webuser node.
We are using Pega CDH where were are running outbound and inbound campaigns where it process and loads heavy data .whenever there is some problem in batch run ,we also see some problem in Inbound where the avg response time spike is very high at that particular time.This does not happn every time but we have observed it some time .
We want to seprate and outbound process in a way when non of these are impacting each other when there are problem in any one outbound node, can you please review our node configuration and suggest any improvements?.
if there is any batch run ,will RTDG or ADM nodes are used for any purpose? if yes ,if any of the batch nodes gets stuck during batch run ,will it affect the RTDG or ADM process which eventually impact the inbound processing due to the above node configuration and how?
***Edited by Moderator Marije to add Support Case Details; ***
