Pega Openspan issue while opening IE Popup in background mode.
Hi Pega Team,
We are using Pega openspan RPA to access IE Application. The openspan file is called using the Windows Scheduler.
In windows scheduler we are using "Running as logged on or not" option so that IE application is called as background process.
With this setup we are able to connect with the IE application. But when we try to open the popup of the IE Application it fails.
Kindly advice how do we open the IE popup in background mode ("Running as logged on or not" option).
Thanks & Regards
Rajesh Mulani.
