    Wipro
Last activity: 19 Jan 2022 21:32 EST
Pega DevOps Pipeline issue- Connection issue between Orchestrator and Candidate server
Hi Team,
I am building a DevOps pipeline for our development / POC environment. To do this I followed below DevOps document of PDN.
I have done with all the configurations and developed a very small pipeline consist of only two steps. 1. Build the product file and 2.deploy the same to Quality Assurance system.
When I do the diagnostic check for the pipeline I found an issue which says - Authentication failed while connecting to QualityAssurance environment. I have tried below things to work around this issue but no luck so far.
Hi Team,
- Checked the DMAppAdmin is enable and it has valid password.
- The DMAppAdmin auth profile has the reference of this user.
- I also checked the log file of Orchestrator node it says, DMReleaseAdmin user is not there in candidate system. So I created this User with all valid password and settings.
- Log also says the Target Dev App is not there in Candidate System. I created a product file from Orchestrator node and migrated the Target Dev App to candidate system. Target Dev App is the app where developer will make changes and build will move from there to higher environment. For now i am NOT considering the Development Branches and Testing rules into my plan
Can someone from community help me solving this issue please, thanks in advance for helping me on this. Please let me know if any further information needed to debug this issue further.
Regards
Rajesh Yadav
