Pega Deployment manager studio 5.2 is not getting configured as expected
Hi Team,
we have configured the deployment manager 5.2 in pega 8.5.2 version and getting configuration error even after following all configuration steps as per below:
Step 1: checked the orchestration URL is correct in general settings.
Step 2: generated client secret and clicked on update authentication profiles. also cross verified the authentication profiles from dev studio having proper client secret, access and revoke token end points
Step 3: Uploaded keystore file in DMKeystore and updated same in the DeploymentManagerClientJWTProfile token profile.
After following all these steps getting the below error:
There is an error fetching details from Deployment Manager services https://XXXXXXXXXXXXX.com/prweb and Deployment Manager Studio will not function as expected. Please verify the configuration of the Orchestrator URL and authentication profiles configured. Error: the HTTP response code of 500 indicated a server error. The response data may contain a reason. // The body of the service's response, which is set up for mapping in the Connector rule, was empty for this service call.
Error screen shot has been attached.
Please suggest if any other steps needs to be followed. Thanks in advance
