Last activity: 28 Sep 2016 2:44 EDT
Pega Decision Management Advanced (7.1) - VBOX File Will Not Load in VirtualBox
I downloaded the Marketing_712_VM_20160223 (3 times today as I though the first 2 might have been corrupted somehow) and cannot get the vbox to be added. I am in the process of removing VirtualBox Manager and re-installing.
Image of error attached
I am running VirtualBox on OSX 10.11.6.
Any guidance would be appreciated.
Hi
On Mac, can you try Keka to uncompress the file?
Regards
Guru
Thanks for your questions. A similar question was asked recently, please take a look at this post for a solution.
https://collaborate.pega.com/question/virtual-box-machine-not-working
Let me know if you require additional help.
Maryrita Styer
Community Manager
I continue to recevied the same error after following the steps in the similar question. I find after unarchiving the zip file with any tool (Stuffit, the Unarchiver, 7zip...) the original zip file becomes corrupted.
Hi
Regards
Guru
Thank you Deshg, Keka seemed to do the trick with the zip files.
Jeff,
Thanks a lot for closing the loop.
We will update the lesson material accordingly by recommending Keka instead of StuffIt Expander.
Marco.
I downloaded the Exersize system for Pega Decision Management Advanced (7.1) [Marketing_712_VM_20160223.zip] and sucessfully started the pega instance using VirtualBox Manager.
To continue with exersizes, I imported the frst jar file C-351-EnvironmentSetup.jar and conitinued with creating the Applicaiton Overlay, as instructed in exersize.
I followed the steps to create the Overlay, however subsequent to create button, I am getting erros as shows in the attachment.
Has anyone experienced similar error or anyone has any resolution for the same ?
Uttam
I downloaded a wrong exercize system. Its wokring as expected.
Sorry, for reporting earlier.
Uttam,
No problem, thanks for letting us know.
Marco.
