Pega CS - v25.1 - Constellation UI - Interaction Case - Rename button '+ Add case' (Button for adding service case)
We are on Pega v25.1 and using Pega CS framework on constellation. We have a requirement to update button label '+ Add case' on Pega CS interaction case. Please refer attached screenshots.
I can see the underlying view is PegaCS-Work-Interactio.pyCaseWorkarea, however, could not identify the field value used for this label, tried updating few field values with 'add case' text but it didn't work.
Looking for suggestions to fulfil this requirement.
Thanks.
