Pega CDH - SQL Error running Simple Segment
I have created a simple Segment rule to pull all the customers. When I save and run the segment I get the following error message:
I am seeing the following error in the log file as well:
Error while performing insert into tmp table with SQL: INSERT INTO segallC0(pySubjectID, pyGroupID, CriteriaID) SELECT customerid AS pySubjectID, customerid AS pyGroupID, 0 AS CriteriaID FROM (SELECT PC2.customerid, PC2.customerid FROM externalmktdata.Engagecustomer PC2 WHERE (PC2.firstname IS NOT NULL)) src org.postgresql.util.PSQLException: ERROR: column reference "customerid" is ambiguous
Any advice?
