Last activity: 25 Apr 2024 11:57 EDT
Deep dive into the Customer Decision Hub Setup wizard
When you start Customer Decision Hub implementation one of the steps is to run the CDH Setup. This process creates all the applications, access groups, data model, and other artifacts for your application. The Setup process is covered in the Pega Academy course End-to-end Pega Customer Decision Hub Implementation. But what exactly happens under the covers? What can you expect in your environment after the Setup wizard has completed?
In this video I explain in some detail what happens when your run CDH Setup. Please use the Q&A feature below if you have any questions. I have attached a detailed log from an run for your reference.
