DCS
Last activity: 9 Nov 2021 14:19 EST
PEGA CDH 8.6 Scenario planner simulation has not populated with Projected value capture & Projected response
We are using PEGA CDH 8.6 Scenario planner simulation to understand the projected responses and business value for two different simulations. However, we don't see Scenario planner dashboard is not populated with Projected value capture & Projected response as expected. Attached the sample screen-print.
We have historical responses in our IH and IH aggregation summary dataset enabled. Are we missing any additional data/configuration to get the scenario planner populated with project value capture?
Nanjundan Chinnasamy
@Nanjundan Chinnasamy
This query could go a number of ways, but I will ask a few questions to get going
- What version are you on?
- What environment are you using? BOE?
- Does this environment have access to production data?
- How did the data get copied? Data migration pipeline?
A few other things
- The left / right tile and the projected responses will not populate as your models have not accumulated enough responses yet for Scenario Planner to rely on the propensities calculated
- The middle tile is populated from the Scenario planner actuals dataset (copied from Prod using the data migration pipeline), do you have this in place?
Here is a link from implementation guide
https://community.pega.com/knowledgebase/articles/pega-customer-decision-hub-implementation-guide/85/enabling-migration-historical-data-scenario-planner
@wongr @Saleem_A - mentioned my CDH colleagues as FYI
