Areteans Technology Solutions
Last activity: 25 Jul 2023 11:53 EDT
Pega 8.8.2 Multi-node Configuration - Node stuck at status JOINING
In my multi-node horizontal cluster for Pega 8.8.2 in Production there are four different VMs. Pega is running on Postgres 14.6 and Tomcat 9.0.74. I have installed Pega CRM 8.8.2 on top of Pega 8.8.2.
The prconfig.xml has been externalized in all four nodes and it contains the below uncommented lines on all four nodes:
<?xml version="1.0" encoding="UTF-8"?> <pegarules>
<env name="initialization/settingsource" value="merged" /> <env name="database/databases/PegaRULES/dataSource" value="java:comp/env/jdbc/PegaRULES"/> <env name="database/databases/PegaDATA/dataSource" value="java:comp/env/jdbc/PegaRULES"/>
</pegarules>
The -DNodeType JVM argument has not been used for Tomcat.
I serially started the four nodes i.e. after node 1 started I started node 2, after nodes 1 and 2 both started I started node 3, after nodes 1 and 2 and 3 all started I started node 4.
I found that node 4 is getting stuck at JOINING state and it is failing to join the cluster.
I found the below lines in PegaRULES.log file of node 4:
</pegarules>
StreamServer.Default 3e83ff42ac77a65b637f3206485d6709 127.0.0.1 NORMAL (new node) 8.8.2 592ca06f-5f11-4dae-88e9-fed579a17c04 This node ==> StreamServer.Default 8e12b4684e61afba3b38dc607bceb1ef 127.0.0.1 JOINING (new node) 8.8.2 085fb6b6-ffc9-4594-a995-89810a19464e StreamServer.Default a03ebfbe8b8cdc80eb0a970057a8c09c 127.0.0.1 NORMAL (new node) 8.8.2 825fcc1d-bec7-4b04-a61f-a4235a1805c9 StreamServer.Default c5547f532e2244702e2209908c640561 127.0.0.1 NORMAL (new node) 8.8.2 6603bdaf-1896-45e1-a1c8-ce9c4c72bbb0 pega 3e83ff42ac77a65b637f3206485d6709 100.96.9.123 running (new node) 8.8.2 67ef89e8-1686-4f12-95fe-09e178dcedaa pega a03ebfbe8b8cdc80eb0a970057a8c09c 100.96.9.89 running (new node) 8.8.2 577e49a7-26df-44e9-afbe-d755637b00d1 pega c5547f532e2244702e2209908c640561 100.96.9.80 running (new node) 8.8.2 02acec05-9f3d-4c94-9536-5bf6bd9d4332
Please suggest what needs to be done to resolve this issue.
Please suggest if different node types should be specified for different node through JVM argument.
