Citizens Bank
Last activity: 14 Apr 2016 16:20 EDT
PEGA 7X installation on windows 2003
Can PEGA 7X be installed on Windows 2003?
I see below system requirement from the installation guide which indicates that it can be installed on any windows version.
The minimum systems requirements to run the Installation and Upgrade Assistant (IUA) are:
- Windows or Linux operating system n 1.25 GB minimum available memory
- 10 GB minimum disk space and at least 8 GB available space in the temporary directory of the root file system
- Java Platform, Standard Edition Development Kit (JDK). Set JAVA_HOME to the root directory of the JDK. For Java 8, you may need to remove from the PATH any references to a Java shortcut.
Thanks in Advance and Appreciate the replies.
