TCS
Last activity: 22 Jul 2015 8:11 EDT
Pega 6.2 installation in windows 8
i am not able to install pega in windows 8.. i have tried many times.....
i have disable the windows user access control to Never..
getting error durring DB2 installation
like 'db2set' is not recognised....
anyone complete the succssfull installation in win8
PEG
Which version of PRPC version you are installing?
Can you paste the stacktrace in this thread?
TCS
Am installing pega PE 6.2 SP1...
could please let me know where can i found Stacktrace...
DB2 is not getting installed...
java also not present in my laptop.
is java needs to be installed before installing pega.. or it will install along with pega
PEG
Java will come with Personal edition. You can find the logs under tomcat folder.
<tomcat>/logs/catalina.log.
Can you change the port number of db while installing PE
May I know your system details like OS version, RAM size etc .
Could you please restart the system and try installing it again.
TCS
How to change the port number of DB
My system OS is windows 8.1(64 bit) 4GB RAM, i5 processor
PEG
Hi Dinesh,
During setup the user db2admin will be created. Therefore, you will need permission to create user to install.
Can you log in as the built-in administrator local system account to run the installation?
TCS
HI,
Please find the catalina.log.
HI,
Jul 21, 2015 10:50:59 AM org.apache.catalina.core.AprLifecycleListener init
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\PRPCPersonalEdition\jdk1.6.0_25\bin;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;c:\program files (x86)\intel\icls client\;c:\program files\intel\icls client\;C:\Windows\system32;C:\Windows;C:\Windows\system32\wbem;C:\Windows\system32\windowspowershell\v1.0\;c:\program files\intel\intel(r) management engine components\dal;c:\program files\intel\intel(r) management engine components\ipt;c:\program files (x86)\intel\intel(r) management engine components\dal;c:\program files (x86)\intel\intel(r) management engine components\ipt;c:\program files (x86)\windows live\shared;c:\program files (x
Jul 21, 2015 10:51:00 AM org.apache.coyote.http11.Http11Protocol init
INFO: Initializing Coyote HTTP/1.1 on http-9090
Jul 21, 2015 10:51:00 AM org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 1476 ms
Jul 21, 2015 10:51:00 AM org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
Jul 21, 2015 10:51:00 AM org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.29
Jul 21, 2015 10:51:00 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor host-manager.xml
Jul 21, 2015 10:51:01 AM org.apache.catalina.startup.HostConfig deployDescriptor
INFO: Deploying configuration descriptor manager.xml
Jul 21, 2015 10:51:01 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive prhelp.war
Jul 21, 2015 10:52:12 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive prsysmgmt.war
Jul 21, 2015 10:52:21 AM org.apache.struts.util.PropertyMessageResources <init>
INFO: Initializing, config='org.apache.struts.util.LocalStrings', returnNull=true
INFO: Initializing, config='org.apache.struts.action.ActionResources', returnNull=true
Jul 21, 2015 10:52:22 AM org.apache.struts.util.PropertyMessageResources <init>
INFO: Initializing, config='ApplicationResources', returnNull=true
Jul 21, 2015 10:52:22 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive prsysmgmt_jboss.war
Jul 21, 2015 10:52:26 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive prsysmgmt_jboss4.war
Jul 21, 2015 10:52:30 AM org.apache.catalina.startup.HostConfig deployWAR
INFO: Deploying web application archive prweb.war
Jul 21, 2015 10:52:32 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
19830421: Loading bootstrap properties from /prbootstrap.properties
Jul 21, 2015 10:52:34 AM com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource
SEVERE: Unable to connect to database. Will only use properties from file.
org.apache.tomcat.dbcp.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory ([jcc][t4][2043][11550][3.59.81] Exception java.net.ConnectException: Error opening socket to server localhost/127.0.0.1 on port 50,000 with message: Connection refused: connect. ERRORCODE=-4499, SQLSTATE=08001)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1549)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1388)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(BasicDataSource.java:1044)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapPropertiesFromDB(PRBootstrapDataSource.java:553)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:534)
at com.pega.pegarules.internal.bootstrap.PRBootstrapDataSource.getBootstrapProperties(PRBootstrapDataSource.java:528)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.<clinit>(PRBootstrap.java:179)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:79)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4135)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4630)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:771)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:546)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:905)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:740)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:500)
at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1277)
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:321)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1053)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:785)
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1045)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:445)
at org.apache.catalina.core.StandardService.start(StandardService.java:519)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:581)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:289)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:414)
Caused by: com.ibm.db2.jcc.am.DisconnectNonTransientConnectionException: [jcc][t4][2043][11550][3.59.81] Exception java.net.ConnectException: Error opening socket to server localhost/127.0.0.1 on port 50,000 with message: Connection refused: connect. ERRORCODE=-4499, SQLSTATE=08001
at com.ibm.db2.jcc.am.dd.a(dd.java:319)
at com.ibm.db2.jcc.am.dd.a(dd.java:337)
at com.ibm.db2.jcc.t4.wb.a(wb.java:400)
at com.ibm.db2.jcc.t4.wb.<init>(wb.java:78)
at com.ibm.db2.jcc.t4.a.y(a.java:317)
at com.ibm.db2.jcc.t4.b.a(b.java:1801)
at com.ibm.db2.jcc.am.jb.a(jb.java:588)
at com.ibm.db2.jcc.am.jb.<init>(jb.java:540)
at com.ibm.db2.jcc.t4.b.<init>(b.java:303)
at com.ibm.db2.jcc.DB2SimpleDataSource.getConnection(DB2SimpleDataSource.java:214)
at com.ibm.db2.jcc.DB2Driver.connect(DB2Driver.java:456)
at org.apache.tomcat.dbcp.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.tomcat.dbcp.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:582)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1556)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createPoolableConnectionFactory(BasicDataSource.java:1545)
... 31 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:351)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:213)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:200)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:529)
at com.ibm.db2.jcc.t4.x.run(x.java:34)
at java.security.AccessController.doPrivileged(Native Method)
at com.ibm.db2.jcc.t4.wb.a(wb.java:386)
... 43 more
19830421: prbootstrap.properties merged with prbootstrap entries in Data-Admin-System-Settings
Jul 21, 2015 10:52:34 AM com.pega.pegarules.internal.bootstrap.PRMiniLoader
19830421: Classes will NOT be loaded from the database; no version specified for Pega-EngineCode.
Jul 21, 2015 10:52:35 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
19830421:
============ PegaRULES Bootstrap Configuration ============
Date: Tue Jul 21 10:52:34 IST 2015
Java Version: Sun Microsystems Inc. 1.6.0_25
Configuration: file:/C:/PRPCPersonalEdition/tomcat/webapps/prweb/WEB-INF/classes/prbootstrap.properties
Pega-EngineCode: <none specified>
JNDI Reference: java:comp/env/jdbc/PegaRULES
(!) Unable to use given database configuration
(!) Unable to locate classes on filesystem
=============== End Bootstrap Configuration ===============
SEVERE: Error initializing PRAppLoader
java.lang.ClassNotFoundException: com.pega.pegarules.internal.bootstrap.phase2.PRBootstrapImpl
at com.pega.pegarules.internal.bootstrap.PRMiniLoader.loadClass(PRMiniLoader.java:365)
at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.checkForStartup(PRBootstrap.java:589)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:387)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:439)
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextInitialized(WebAppLifeCycleListenerBoot.java:83)
SEVERE: Problem during method invocation (contextInitialized)
java.lang.RuntimeException: PRAppLoader was not properly initialized, unable to load class com.pega.pegarules.web.servlet.WebAppLifeCycleListener
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getImplementationOf(PRBootstrap.java:213)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getEntry(PRBootstrap.java:303)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.getMethod(PRBootstrap.java:283)
at com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:388)
Jul 21, 2015 10:52:35 AM org.apache.catalina.core.StandardContext start
SEVERE: Error listenerStart
SEVERE: Context [/prweb] startup failed due to previous errors
Jul 21, 2015 10:52:35 AM com.pega.pegarules.internal.bootstrap.PRMiniLoader
Jul 21, 2015 10:52:36 AM com.pega.pegarules.internal.bootstrap.PRBootstrap
19830421:
Date: Tue Jul 21 10:52:35 IST 2015
at com.pega.pegarules.internal.web.servlet.WebAppLifeCycleListenerBoot.contextDestroyed(WebAppLifeCycleListenerBoot.java:67)
at org.apache.catalina.core.StandardContext.listenerStop(StandardContext.java:4174)
at org.apache.catalina.core.StandardContext.stop(StandardContext.java:4778)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4675)
SEVERE: Problem during method invocation (contextDestroyed)
Jul 21, 2015 10:52:36 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory docs
INFO: Deploying web application directory examples
Jul 21, 2015 10:52:37 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory ROOT
Jul 21, 2015 10:52:37 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-9090
Jul 21, 2015 10:52:37 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:9009
Jul 21, 2015 10:52:37 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/32 config=null
Jul 21, 2015 10:52:37 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 96855 ms
Jul 21, 2015 10:52:58 AM org.apache.coyote.http11.Http11Protocol pause
INFO: Pausing Coyote HTTP/1.1 on http-9090
Jul 21, 2015 10:52:59 AM org.apache.catalina.core.StandardService stop
INFO: Stopping service Catalina
Jul 21, 2015 10:52:59 AM org.apache.coyote.http11.Http11Protocol destroy
INFO: Stopping Coyote HTTP/1.1 on http-9090
PEG
From the below stack trace it is evident that server is not able connect to database.
Can you let us know the port number of db2 you had given while installing db?
Can you check the database connectivity with server. You can either specify in context.xml under config folder or prconfig.xml under prweb?
Pega 6.2 SP1 is not supported on Windows 8. Please see the platform support guide for details.
If you are using Personal Edition - its best to use the latest from the PDN
TCS
Hi Gollg
I am getting this error
[exec] PRPC_BUILD BEGINS
[exec] Wed 07/22/2015
[exec] 10:49 AM
[exec] DB21009E This command must be launched from a command window running with full administrative privileges.stopping db2 ...
[exec] System error 5 has occurred.
[exec] Access is denied.
[exec] Starting db2 ...
The DB2 was installed as adminstartor and i also looged in as adminstartor
PEG
I think,because of incompatibilty issue you weren't able to install. Generally provided steps would work for PE installation.
