Pega 7.4 - Test DB connectivity for ALPHADB database, throws oracle ORA-02391.
While doing Test DB connectivity for ALPHADB database, we are getting oracle ORA-02391.
We are using Pega 7.4.
System Configuration - docker, tomcat, oracle
Our application has 2 docker nodes.
However this bahaviour is seen only on 1 docker node. 2nd node always works fine and returns success connecting to database.
ALPHADB Database is configured via JDBC URL as shared below::
jdbc:oracle:thin:@(DESCRIPTION=(ADDRESS_LIST=(LOAD_BALANCE=on)(ADDRESS = (PROTOCOL = TCP) (HOST = <<host1.com>>)(PORT = 1521))(ADDRESS = (PROTOCOL = TCP)(HOST = <<host2.com>>) (PORT = 1521))(ADDRESS = (PROTOCOL = TCP)(HOST = <<host3.com>>)(PORT = 1521))(ADDRESS = (PROTOCOL = TCP) (HOST = <<host4.com>>)(PORT = 1521))(ADDRESS = (PROTOCOL = TCP)(HOST = <<host5.com>>) (PORT = 1521))(ADDRESS = (PROTOCOL = TCP)(HOST = <<host6.com>>)(PORT = 1521))(ADDRESS = (PROTOCOL = TCP) (HOST = <<host7.com>>)(PORT = 1521))(ADDRESS = (PROTOCOL = TCP) (HOST = <<host8.com>>)(PORT = 1521)))(CONNECT_DATA=(SERVER=DEDICATED)(SERVICE_NAME=<<removed>>)))
1.Open Pega 7.4 Designer Studio
2.Go To Records --> Database --> ALPHADB
3.Click ALPHADB database and click on "Test Connection"
Error Message
| Status Value: Database-General Connection Exception 2391 61000 ORA-02391: exceeded simultaneous SESSIONS_PER_USER limit DatabaseException caused by prior exception: java.sql.SQLException: ORA-02391: exceeded simultaneous SESSIONS_PER_USER limit | SQL Code: 2391 | SQL State: 61000 |
1. Has anyone encountered this error and how did they resolve it
2.Very poor documentation on HikariPool - https://community.pega.com/knowledgebase/articles/hikaricp-connection-pool-configuration
3. Where are the details of HikariPool configuration stored and how can I remove them from tomcat
Please refer attachment ExceptionTrace.txt for errors related to HikariPool
Thank You!!
regards
Amit
Hi Amit,
Looking into the SR details, I read that the issue is resolved by performing the following step- Flush out DB connections and increased the number of DB connection sessions to 800 .
Thanks!
