IT-Huset i Norden AB
SE
Pega 7 full login url missing from VM Console (VMWare and VirtualBox)
When i download the latest the latest exercise system from LSA Course (LSA_719_VM_20160708), and then trying to run it either by VMWare or Virtual Box, the url for the Pega 7 Login is missing on the console screen when VM starts..... Attaching the screen shot of the console with this post.
Kindly let me i know if i have missed something otherwise kindly share the url in this post.
Thanks, Amitabh
Updated: 19 Aug 2016 8:27 EDT
Ai4Process
This is probably because the VirtualBox network settings for this VM are not correct.
Could you try one then the other:
- Adapter 1: Attached to: NAT - Adapter type: PCnet-FAST III - cacle connected: checked
- Adapter 1: Attached to: Bridged Adapter - Adapter type: PCnet-FAST III cacle connected: checked
Hopefully one of those 2 will work for you
Damien
SE
Hi Damien,
Out of the above two options, only the first option is showing the full url for the Pega 7 login - http:// Proprietary information hidden:9080/
But still its not working when i try the url in the browser. Please have a look at the attached snapshot.
SE
I tried the below old setting as in the previous exercise system (LSA_719_VM_20160208) and it started working :)
Adapter 1: Attached to: Host-only Adapter - Adapter type: Intel PRO/1000 MT Server (82545EM) - cable connected: checked
Ai4Process
Glad it is working.
Odly enough, sometimes changing settings and reverse configuration do the trick.
Damien
I had the same issue and when I tried with option 1, gave me URL but no access. After trying Amitabh's solution, it worked for me as well.
SSCL
These solutions don't work for me, any other solutions which you guys can suggest?
Pega
I am facing the same issue. tried out above solutions but not able to solve it.
SG
Try configuring the network adapter to Host-only. NAT usually presents a problem for VirtualBox. If you have further issues, please write to [email protected] with screenshots.
Infosys
This setting is not working for me. I am geeting the atatched error when i browse it. Can any one help me.
VM console browser link is not working
Infosys
I am stuck, can someone help me on this
Infosys
I am using the below NW setting. I tried multiple combination but no use.
Updated: 22 Nov 2016 22:11 EST
Unfortunately this is a virtual machine network configuration issue that is also dependant on your local machine network hardware/software. Pega has no control over this as it is not related to the delivered virtual machine OVA file. The best source of expertise to refer to in order to solve the problem would be the virtual box forums (https://forums.virtualbox.org/). You also have the option of running in another vendors virtual machine as well which may be more compatible with your network hardware/software on your host machine. In the past, people have had success changing to a VMWare virtual machine and importing into this machine.
Updated: 22 Nov 2016 17:10 EST
Infosys
I tried on VM ware workstation player but no luck. Any other way to get the training SW
Updated: 23 Nov 2016 16:01 EST
The only option is to import the supplied OVF file to your virtual machine player. What exactly is the problem you experienced with the configuration ?
Infosys
When i am trying to access the URL given by VM i am getting an error. Attached error
Infosys
finally it worked when i append the prweb/PRServlet.
http:// Proprietary information hidden:9080/prweb/PRServlet
Thank you all
UBS
Hello Sunil
I am getting the similar issue. what configuration you used. I am using below address. BUT no response
This site can’t be reached
Proprietary information hidden refused to connect.
Hello Sunil
- Search Google for 192 168 101 9080 prweb PRServlet
SG
If you are connected to VPN, disconnect from it.
Aside from posting a message, What else have you tried and what else have you checked in your effort to get it to function ?
Have you tried to ping that address from your local machine to see if it is reachable ?
Alter Domus
IE
Amitabh's solution worked for me.
I know this is an old thread but I thought I'd add some experience of my own:
Summary: Your results will depend on the network to which you are connected!
I am using virtualbox. Originally I had Adapter 1 configured in Bridged mode (as instructed in the VM user guide).
From my hotel room the vm reported a url of "http://:9080" and ifconfig showed no IP address assigned to the adapter.
I also tried with my VPN running but got the same result.
I changed the adapter configuration from Bridged mode (the recommendation) to Host-only. On restarting the vm an IP address is assigned but there is no access from Pega to external addresses.
In a happy experiment I reset the configuration back to Bridged mode and when I got into my customer office today I tried again from their wifi network... and it works! An IP address is assigned and I can access the Pega exercise system from a browser.
So to those of you who see a URL of http://:9080 I would say: go forth... try the coffee shop around the corner... try a friend's house (or a friendly customer)... because it definitely depends on the network as much as anything else.
Toyota Financial Services
Hi, the above mentioned method worked when I use my mobile hotspot.
But, what could have been the problem for the home network, as I am not always able to connect to Mobile network.
UHG
I even struggled with this issue. Finally under vm settings; I updated the network connection to NAT and restarted the vm. This time I got the URL and when I used the same in the browser, I got the login page. Now I am able on work on this.
bank of america
Thank you very much MCCAR1.
When I removed my LAN cable and connected using wifi my problem got resolved.
Really appreciated!
