Pega 6.1 SP2 to Pega 7.2.2 Rules Upgrade - In place db upgrade- Resume IndexReference_11.jar import takes more time is that normal - any suggestion to make import faster
Pega 6.1 SP2 to Pega 7.2.2 Rules Upgrade - In place db upgrade- Resume IndexReference_11.jar import takes more time is that normal - any suggestion to make import faster. Did any one had similar issue?
Java: jdk1.7.0_80 - [echo] *** JVM Arguments -Xmx1536m -XX:MaxPermSize=768m ***
Oracle 11g
import of (61 of 96) completed with in 6 hours. but IndexReference_11.jar single file takes more than 10 hours.
[java] ============ PegaRULES Bootstrap Configuration ============
[java] Date: Wed Apr 12 08:47:29 EDT 2017
[java] Java Version: Oracle Corporation 1.7.0_80
[java] Configuration: file:/C:/115290_Pega722/Temp/PegaInstallTemp-08-April-2017-18.10.10/prbootstrap.properties
[java] Pega-EngineCode: 07-10-27
[java] ASM Version: -560251499
[java] JDBC Driver: oracle.jdbc.OracleDriver
[java] JDBC URL: jdbc:oracle:thin:@//fl1dr023918:1521/LDB070N
[java] JDBC User: DEPLOYPEGA7
[java] Database: Oracle Oracle Database 11g Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
[java] With the Partitioning, Automatic Storage Management, OLAP, Data Mining
[java] and Real Application Testing options
[java] Driver: Oracle JDBC driver Proprietary information hidden.0
[java] Active CodeSets: pega-enginecode:07-10-27 at (latest patch)
Oracle 11g
java] 2017-04-11 17:14:07,352 [ main] [ ] [ ] ( archive.importer.Upgrader) INFO - Starting the Rules Load
[java] 2017-04-11 17:14:07,352 [ main] [ ] [ ] (hive.importer.AppBundleHandler) INFO - Resuming from IndexReference_11.jar
[java] 2017-04-11 17:14:07,352 [ main] [ ] [ ] (hive.importer.AppBundleHandler) INFO - Started import of IndexReference_11.jar (63 of 96)
[java] 2017-04-11 17:14:07,352 [ main] [ ] [ ] (y.internal.PRRuleMgmtUtilsImpl) INFO - IndexReference_11.jar is v6 Archive
[java] 2017-04-11 17:14:13,738 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Bytes input per interaction warning threshold: 50M
[java] 2017-04-11 17:14:13,938 [ main] [ ] [ ] (ternal.dictionary.ClassMapImpl) INFO - ClassMap using multi-tenant environment: false
[java] 2017-04-11 17:14:13,938 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class group definitions
[java] 2017-04-11 17:14:14,208 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 219 class group definitions
[java] 2017-04-11 17:14:16,207 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Reading the class definitions
[java] 2017-04-11 17:15:53,654 [ main] [ ] [ ] (ary.ClassMapDatabasePageReader) INFO - Read 22767 class definitions
[java] 2017-04-11 17:15:58,478 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database product: Oracle
[java] 2017-04-11 17:15:58,478 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Database version: Oracle Database 11g Enterprise Edition Release Proprietary information hidden.0 - 64bit Production
[java] 2017-04-11 17:15:58,478 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver: Oracle JDBC driver
[java] 2017-04-11 17:15:58,478 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Driver version: Proprietary information hidden.0
[java] 2017-04-11 17:15:58,478 [ main] [ ] [ ] ( internal.access.DatabaseImpl) INFO - Version of JDBC supported by driver: 11.2
[java] 2017-04-11 17:16:57,640 [ main] [ ] [ ] ( internal.loaders.FastLoader) INFO - Performing Fast Deployment with Batch Enabled: true
[java] 2017-04-11 17:16:57,834 [ main] [ ] [ ] (pboard.StorageStreamCommonImpl) INFO - Storage stream version is 6
[java] 2017-04-11 17:40:30,532 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 46534 of 73694 (63.14%): 169 committed, 46365 skipped, 1:37 minutes remaining
[java] 2017-04-11 18:04:24,819 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 46634 of 73694 (63.28%): 269 committed, 46365 skipped, 15:19 minutes remaining
[java] 2017-04-11 18:28:16,102 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 46734 of 73694 (63.42%): 369 committed, 46365 skipped, 29:05 minutes remaining
[java] 2017-04-11 18:53:11,675 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 46834 of 73694 (63.55%): 469 committed, 46365 skipped, 42:39 minutes remaining
[java] 2017-04-11 19:18:12,148 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 46934 of 73694 (63.69%): 569 committed, 46365 skipped, 56:40 minutes remaining
[java] 2017-04-11 19:41:10,352 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47034 of 73694 (63.82%): 669 committed, 46365 skipped, 70:34 minutes remaining
[java] 2017-04-11 20:03:19,506 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47134 of 73694 (63.96%): 769 committed, 46365 skipped, 83:10 minutes remaining
[java] 2017-04-11 20:28:02,669 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47234 of 73694 (64.09%): 869 committed, 46365 skipped, 95:08 minutes remaining
[java] 2017-04-11 20:56:26,023 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47334 of 73694 (64.23%): 969 committed, 46365 skipped, 108:24 minutes remaining
[java] 2017-04-11 21:34:10,344 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47434 of 73694 (64.37%): 1069 committed, 46365 skipped, 123:32 minutes remaining
[java] 2017-04-11 21:57:20,740 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47534 of 73694 (64.50%): 1169 committed, 46365 skipped, 143:40 minutes remaining
[java] 2017-04-11 22:20:55,174 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47634 of 73694 (64.64%): 1269 committed, 46365 skipped, 155:33 minutes remaining
[java] 2017-04-11 22:43:15,423 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47734 of 73694 (64.77%): 1369 committed, 46365 skipped, 167:30 minutes remaining
[java] 2017-04-11 23:06:08,646 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47834 of 73694 (64.91%): 1469 committed, 46365 skipped, 178:38 minutes remaining
[java] 2017-04-11 23:29:12,033 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 47934 of 73694 (65.04%): 1569 committed, 46365 skipped, 189:55 minutes remaining
[java] 2017-04-11 23:53:21,891 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48034 of 73694 (65.18%): 1669 committed, 46365 skipped, 201:09 minutes remaining
[java] 2017-04-12 00:16:49,376 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48134 of 73694 (65.32%): 1769 committed, 46365 skipped, 212:51 minutes remaining
[java] 2017-04-12 00:38:24,636 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48234 of 73694 (65.45%): 1869 committed, 46365 skipped, 224:01 minutes remaining
[java] 2017-04-12 01:00:09,667 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48334 of 73694 (65.59%): 1969 committed, 46365 skipped, 234:03 minutes remaining
[java] 2017-04-12 01:22:25,793 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48434 of 73694 (65.72%): 2069 committed, 46365 skipped, 244:02 minutes remaining
[java] 2017-04-12 01:44:19,060 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48534 of 73694 (65.86%): 2169 committed, 46365 skipped, 254:10 minutes remaining
[java] 2017-04-12 02:06:56,523 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48634 of 73694 (65.99%): 2269 committed, 46365 skipped, 263:57 minutes remaining
[java] 2017-04-12 02:28:31,410 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48734 of 73694 (66.13%): 2369 committed, 46365 skipped, 274:00 minutes remaining
[java] 2017-04-12 02:50:09,988 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48834 of 73694 (66.27%): 2469 committed, 46365 skipped, 283:23 minutes remaining
[java] 2017-04-12 03:12:13,998 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 48934 of 73694 (66.40%): 2569 committed, 46365 skipped, 292:40 minutes remaining
[java] 2017-04-12 03:34:42,339 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49034 of 73694 (66.54%): 2669 committed, 46365 skipped, 302:02 minutes remaining
[java] 2017-04-12 03:57:31,161 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49134 of 73694 (66.67%): 2769 committed, 46365 skipped, 311:29 minutes remaining
[java] 2017-04-12 04:19:47,861 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49234 of 73694 (66.81%): 2869 committed, 46365 skipped, 320:58 minutes remaining
[java] 2017-04-12 04:41:18,786 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49334 of 73694 (66.94%): 2969 committed, 46365 skipped, 330:04 minutes remaining
[java] 2017-04-12 05:02:39,070 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49434 of 73694 (67.08%): 3069 committed, 46365 skipped, 338:39 minutes remaining
[java] 2017-04-12 05:24:10,705 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49534 of 73694 (67.22%): 3169 committed, 46365 skipped, 347:02 minutes remaining
[java] 2017-04-12 05:45:19,445 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49634 of 73694 (67.35%): 3269 committed, 46365 skipped, 355:23 minutes remaining
[java] 2017-04-12 06:06:29,614 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49734 of 73694 (67.49%): 3369 committed, 46365 skipped, 363:26 minutes remaining
[java] 2017-04-12 06:27:44,995 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49834 of 73694 (67.62%): 3469 committed, 46365 skipped, 371:22 minutes remaining
[java] 2017-04-12 06:48:52,400 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 49934 of 73694 (67.76%): 3569 committed, 46365 skipped, 379:14 minutes remaining
[java] 2017-04-12 07:11:17,903 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 50034 of 73694 (67.89%): 3669 committed, 46365 skipped, 386:55 minutes remaining
[java] 2017-04-12 07:32:56,536 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 50134 of 73694 (68.03%): 3769 committed, 46365 skipped, 395:06 minutes remaining
[java] 2017-04-12 07:54:32,929 [ main] [ ] [ ] ( internal.util.MoveLog) INFO - Processed 50234 of 73694 (68.17%): 3869 committed, 46365 skipped, 402:48 min
