Accenture
Last activity: 21 May 2019 8:15 EDT
PCS 7.3 Search functionality : Issue with Base Name
PCS 7.2 In Development portal we had search for cases based on Alias Name. When you search for a case highest version of all the cases, with same Alias Name appears.
In PCS 7.3 this filter for cases is moved from Alias name to Base Name which is a new property introduced in 7.3. Through the post upgrade Activities they have set base name and it serves the purpose just as it did in 7.2. But for any new Cases created with same name the logic in the screen flow to set Base Name is not consistent with that in Post upgrade activities and different versions of same case appear in the search.
I wanted to know the logic behind the Base Name and if anyone faced this issue before.
Looks like the query is more related to framework. Can you please tag it to appropriate topic?
