- Contact a Moderator
Back to top
Back to top
Related content:
BIX Extract output filename which is in (.csv) file format
How to handle comma values in BIX extract file if we output is in CSV format
Ask the Expert - BIX Output Formats with Yesovardhan Kambhampaty
How is the output format of a field in the report definition converted?
Can BIX on PEGA 7.3 output format be Database if it is Cloud environment?
BIX Extract File name with date value in csv output format
Can BIX output files on every node onclustered environments?
Format Validation Error when width of DateTime column is modified on Report Definition Output
Date Format is showing incorrect format in Excel file on Pega's "Export to Excel"
