Can BIX output files on every node onclustered environments?
Hi all
Currently we have Pega 7.2 with BIX enabled, we are facing some requeriment which states that we need to generate an output file so that Business Intelligence people could grab that file and do their things. We plan to implement that through BIX because that package let us generate files from DB, Reports, etc
Thing is our Pega environment is multinode and we need to generate the output file on each node Pega is running, or at least generate the output file on node 1 destination directory and from then copy that file to the other nodes, I'm thinking more on some sync from node 1 and forth so every destinatio directory on each node gets a copy of that file, it's that possible from Pega & BIX ?
Thank you!
