Oracle Stored procedure which will return a value back to PEGA
I am attempting to call a stored procedure from Oracle which will return a value back to PEGA. I continue to get various errors on the tracer. Is there a tutorial or some solid information with “clear” examples…
I have already reviewed to following:
https://pdn.pega.com/how-process-result-set-returned-oracle-stored-procedures
Does a function within PEGA need to be create first…
If so where and how.
Please refer to below links on how to call a stored procedure using Connect-SQL
https://collaborate.pega.com/discussion/it-possible-call-stored-procedures-pega
https://pdn.pega.com/node/8755/book_pdf
https://community.pega.com/support/support-articles/error-while-calling-sql-function-rdb-list
In case if you are still facing issues, please share the error you are getting in tracer.
