Stored Procedure
What rules in Pega if any other than Connect-SQL use the stored procedures?
Little confused about you query
But if you asking how to call store procedure in pega then answer is through connect-sql rule only
https://pdn.pega.com/node/8755/book_pdf
But if you looking for which all rules refer store procedure then there might be a lot of places
Thank You
which other rules can directly use store procedure ?
Please let me know if anyone has any other suggestions
There are few store procedure, for example SP sppr_sys_reservequeueitem_b is used purely for agent processing.
There are different SP which are called by different rules based on their design
Not sure how much I have answered your query, but if I have got it wrong then please provide exact details that you looking for. I might be able to check for that
Hi Shekhar,
How to optimize "sppr_sys_reservequeueitem" stored procedure ??
Hi Rajesh,
Which version of prpc are you using?I guess we can do some modification in stored procedure query for 7.1.8 to optimize it.
Abhinav
