Cognizant
Last activity: 30 Aug 2023 23:39 EDT
ORA-14402: updating partition key column would cause a partition change
Hi Team,
I'm getting error message"ORA-14402: updating partition key column would cause a partition change" while approving a request in the workbasket. As part of the code we are not updating any partition column, but in the background a merge query is auto generating and trying to update the partition column. Due to this error, unable to approve the requests. Please share your thoughts...
Error Message: [MSG][Error in commit()][STACK][com.pega.pegarules.pub.database.DatabaseException: ORA-14402: updating partition key column would cause a partition change DatabaseException caused by prior exception: java.sql.BatchUpdateException: ORA-14402: updating partition key column would cause a partition change | SQL Code: 14402 | SQL State: 72000 DatabaseException caused by prior exception: java.sql.SQLException: ORA-14402: updating partition key column would cause a partition change | SQL Code: 14402 | SQL State: 72000 : SQL: MERGE INTO DATA.pc_assign_workbasket
