Applies to Pega Platform versions 8.5.1 through 8.6.2
Prerequisite
For additional information, see also the more recently published document, Update fails with ORA-01451, ORA-02429, and ORA-02443 [SDR-301].
Symptoms
The issue described in this document can occur in all update scenarios for Pega Platform™, Pega 8.5.1 through 8.6.2.
DDL generated for an update to Pega 8.5.1 and later releases throws an error during installation.
The following ALTER statement causes the error:
ALTER TABLE PC_ASSIGN_WORKBASKET DROP CONSTRAINT GETNEXTWORKINWORKGROUP
The DROP CONSTRAINT statement causes this error:
ERROR at line 1: ORA-02443: Cannot drop constraint - nonexistent constraint
The error caused by the DROP CONSTRAINT statement indicates that the constraint does not exist. Upon investigation, the user discovered that GETNEXTWORKINWORKGROUP is a functional index and not a constraint. Therefore, the user tried using the DROP INDEX statement but received the following error:
ERROR at line 1:
ORA-02429: cannot drop index used for enforcement of unique/primary key
ORA-06512: at line 5
Errors
A series of errors occur as shown in the following examples:
ERROR at line 1:
Explanation
Under certain circumstances the Oracle database enforces the primary key constraint for a table by using an index that is not the primary key index. This is an optimization that Oracle makes to reduce the number of unnecessary indices. However, this optimization confuses the Pega update scripts and causes the update to fail with the following error:
When this happens, Oracle enforces the Primary Key (PK) constraint using the
GETNEXTWORKINWORKGROUP index, which is different from the index specified by the Pega Platform when it is shipped.
Solution
Complete the following steps for your Oracle database before you attempt to run the installation for a Pega Platform update:
- Drop the primary key constraint on the table.
- Drop the index that was used to optimize.
- Add the primary key constraint back.
- Add the index back.
Related Content
Pega Documentation
Troubleshooting failed database connection after update or patch (Oracle database)
Troubleshooting failed system startup after update or patch (Oracle database)
Optimizing database properties
Pega Support Document
