De Lage Landen Financial Services
Last activity: 8 Feb 2016 1:02 EST
New REST Integration wizard throwing error when Data Layer is included
We are using PRPC v7.1.8.
We are to consume a REST service using POST method and passing JSON payload as request. We are using the 'New REST Integration' wizard to generate the Integration and Data rules.
In the wizard, when we are testing the integration after selecting methods, everything looks good - we are getting a response with expected data. When we are selecting class name, ruleset, data page name, etc. and continuing with generation of rules, the wizard is throwing a StackOverflow exception. However, when uncheck the 'Generate Data Layer' section, the wizard is working fine.
It would be very helpful if we can get any guidance in this regards.
This sounds like a familiar issue. Can you please post the error stacktrace here?
The following is the stacktrace from PegaRULES log:
2016-02-05 00:04:35,179 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] ( internal.util.PRServiceUtils) ERROR roys - Rule Generator thrown exception:
java.lang.StackOverflowError
at java.util.TreeSet.addAll(TreeSet.java:300)
at java.util.TreeSet.<init>(TreeSet.java:160)
at com.pega.pegarules.integration.config.internal.mapping.RuleGeneratorREST.addRequestDTSteps(RuleGeneratorREST.java:778)
at com.pega.pegarules.integration.config.internal.mapping.RuleGeneratorREST.addRequestDTSteps(RuleGeneratorREST.java:822)
at com.pega.pegarules.integration.config.internal.mapping.RuleGeneratorREST.addRequestDTSteps(RuleGeneratorREST.java:804)
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] ( internal.util.RuleSaver) ERROR roys - Canceling rule generation, java.lang.StackOverflowError
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Record cleanup starting...
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Estimated number of record(s) to delete: 0
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Records are distributed across 0 batche(s)
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Deleting 0 batch logs
2016-02-05 00:04:35,194 [ PegaRULES-Batch-2] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Record cleanup complete.
2016-02-05 00:04:35,929 [ http-bio-80-exec-54] [TABTHREAD0] [ ] [ DLLCOrig:01.01.01] (a_DataModel_DataSources.Action) ERROR assassinvine| Proprietary information hidden roys - Error calculating time elapsed
2016-02-05 00:05:26,695 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] ( internal.async.Agent) INFO - System date: Fri Feb 05 00:05:26 CET 2016 Total memory: 3,977,773,056 Free memory: 820,075,488 Requestor Count: 14 Shared Pages memory usage: 0%
2016-02-05 00:15:26,700 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] ( internal.async.Agent) INFO - System date: Fri Feb 05 00:15:26 CET 2016 Total memory: 3,977,773,056 Free memory: 642,877,952 Requestor Count: 14 Shared Pages memory usage: 0%
2016-02-05 00:25:26,706 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] ( internal.async.Agent) INFO - System date: Fri Feb 05 00:25:26 CET 2016 Total memory: 3,977,773,056 Free memory: 485,585,640 Requestor Count: 14 Shared Pages memory usage: 0%
2016-02-05 00:28:39,254 [ http-bio-80-exec-47] [TABTHREAD0] [ ] [ DLLCOrig:01.01.01] (al.mapping.RuleGeneratorCommon) INFO assassinvine| Proprietary information hidden roys - DataPageRulesetVersion is not specified, using RuleSetVersion parameter value
2016-02-05 00:28:39,270 [ http-bio-80-exec-47] [TABTHREAD0] [ ] [ DLLCOrig:01.01.01] ( internal.util.PRServiceUtils) ERROR assassinvine| Proprietary information hidden roys - Rule Generator thrown exception:
2016-02-05 00:35:26,711 [egaRULES-MasterAgent] [ STANDARD] [ ] [ ] ( internal.async.Agent) INFO - System date: Fri Feb 05 00:35:26 CET 2016 Total memory: 3,981,967,360 Free memory: 1,164,439,024 Requestor Count: 14 Shared Pages memory usage: 0%
2016-02-05 00:35:33,164 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] ( internal.util.PRServiceUtils) ERROR roys - Rule Generator thrown exception:
2016-02-05 00:35:33,164 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] ( internal.util.RuleSaver) ERROR roys - Canceling rule generation, java.lang.StackOverflowError
2016-02-05 00:35:33,180 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Record cleanup starting...
2016-02-05 00:35:33,180 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Estimated number of record(s) to delete: 0
2016-02-05 00:35:33,180 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Records are distributed across 0 batche(s)
2016-02-05 00:35:33,180 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Deleting 0 batch logs
2016-02-05 00:35:33,180 [ PegaRULES-Batch-5] [ STANDARD] [ ] [ DLLCOrig:01.01.01] (l.RuleSaverUtils$RecordRemover) INFO roys - Record cleanup complete.
Can you also provide your JSON sample used for rule generation?
Sample Request:
{"query":{"bool":{"must":[{"match":{"countryCode":"US"}},{"nested":{"path":"partner","query":{"bool":{"must":[{"wildcard":{"partner.partnerName":"*advanced*"}}]}}}}]}}}
Sample Response:
Sample Request:
Sample Response:
{"took":15,"timed_out":false,"_shards":{"total":1,"successful":1,"failed":0},"hits":{"total":54,"max_score":4.3995514,"hits":[{"_index":"partnersite-index","_type":"dll","_id":"e04e57f2-8348-11e1-b9ab-0130f2fd1ea0","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"e04e57f2-8348-11e1-b9ab-0130f2fd1ea0","partner":[{"legacyPartnerId":"e3ebca0e-8348-11e1-b9ab-0130f2fd1ea0","olmVendorId":"??","sbuId":"05","partnerName":"ADV TOTAL SYSTEMS INC","isActive":"1","isSingleApp":"0","partnerDba":[{"legacyPartnerDbaId":"c1a1343a-897d-11e1-b516-7326934a1a96","partnerDbaName":"ATS COMPUTERS"}]}],"partnerSiteName":"","partnerSiteNumber":"0000103116-0002","isPrimarySite":"0","isActive":"1","address1":"13200 SW 128TH ST STE B4","address2":"","address3":"","address4":"ID J3140","city":"MIAMI","county":"MIAMI-DADE","stateAbbr":"FL","postalCode":"33186-5826","countryCode":"US","telephone":"3054774567","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"d20518aa-3ea5-11e0-9cad-25ffa447ec02","salesRepName":"Ossolinski, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"be4f743a-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100340","programName":"TF EQUIPMENTS IPTL","isActive":"1"},{"legacyProgramId":"c907717a-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100341","programName":"TF EQUIPMENTS TMM1","isActive":"1"},{"legacyProgramId":"d2de0f56-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100342","programName":"TF EQUIPMENTS","isActive":"1"},{"legacyProgramId":"b46b1b99-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100339","programName":"TF EQUIPMENTS GNRL","isActive":"1"},{"legacyProgramId":"6de50336-d829-11e2-944b-c77acc2e114f","programNumber":"100679","programName":"TF_FLEXPOD COMMERCIAL","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"023327d6-834e-11e1-b9ab-0130f2fd1ea0","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"023327d6-834e-11e1-b9ab-0130f2fd1ea0","partner":[{"legacyPartnerId":"05f781e9-834e-11e1-b9ab-0130f2fd1ea0","olmVendorId":"??","sbuId":"05","partnerName":"ADVNETWORX INC","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000104067-0001","isPrimarySite":"1","isActive":"1","address1":"ID J5417","address2":"5710 HIGH POINT RD STE K PMB 189","address3":"","address4":"","city":"GREENSBORO","county":"GUILFORD","stateAbbr":"NC","postalCode":"27407-7047","countryCode":"US","telephone":"9194672691","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"d20518aa-3ea5-11e0-9cad-25ffa447ec02","salesRepName":"Ossolinski, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"c7d0bc3b-6d24-11df-a92b-91cdf4ae16be","salesRepName":"Myers, Matthew"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"be4f743a-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100340","programName":"TF EQUIPMENTS IPTL","isActive":"1"},{"legacyProgramId":"c907717a-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100341","programName":"TF EQUIPMENTS TMM1","isActive":"1"},{"legacyProgramId":"d2de0f56-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100342","programName":"TF EQUIPMENTS","isActive":"1"},{"legacyProgramId":"b46b1b99-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100339","programName":"TF EQUIPMENTS GNRL","isActive":"1"},{"legacyProgramId":"6de50336-d829-11e2-944b-c77acc2e114f","programNumber":"100679","programName":"TF_FLEXPOD COMMERCIAL","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"bfff44d0-8352-11e1-b9ab-0130f2fd1ea0","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"bfff44d0-8352-11e1-b9ab-0130f2fd1ea0","partner":[{"legacyPartnerId":"c3bee4eb-8352-11e1-b9ab-0130f2fd1ea0","olmVendorId":"??","sbuId":"05","partnerName":"ADV CONNECTIONS MANAGEMENT IN","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000104848-0001","isPrimarySite":"1","isActive":"1","address1":"PO BOX 94840","address2":"","address3":"","address4":"ID J6365","city":"ALBUQUERQUE","county":"BERNALILLO","stateAbbr":"NM","postalCode":"87199-4840","countryCode":"US","telephone":"5058888822","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"3703fdf4-7436-11e1-837d-2514ba47b3f1","salesRepName":"Leahy, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"5833ecf0-7cdd-11e1-bc8c-a3e1d4db657e","salesRepName":"Sitko, Peter"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"b71ea67f-a78e-11e2-ad4e-67abe344c709","programNumber":"100666","programName":"OE_VENDOR 33/33","isActive":"1"},{"legacyProgramId":"0e25e64b-a790-11e2-ad4e-67abe344c709","programNumber":"100667","programName":"OE_VENDOR 20/0","isActive":"1"},{"legacyProgramId":"341c14e2-7d95-11e1-97ec-8d7ceef5ce5f","programNumber":"100304","programName":"OE_VENDOR","isActive":"1"},{"legacyProgramId":"d2de0f56-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100342","programName":"TF EQUIPMENTS","isActive":"1"},{"legacyProgramId":"9661bc0a-a791-11e2-ad4e-67abe344c709","programNumber":"100668","programName":"OE_VENDOR 25/0","isActive":"1"},{"legacyProgramId":"9c9796b6-a792-11e2-ad4e-67abe344c709","programNumber":"100669","programName":"OE_VENDOR 25/25","isActive":"1"},{"legacyProgramId":"6de50336-d829-11e2-944b-c77acc2e114f","programNumber":"100679","programName":"TF_FLEXPOD COMMERCIAL","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"df19b95e-8351-11e1-99bb-15a7532ccabd","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"df19b95e-8351-11e1-99bb-15a7532ccabd","partner":[{"legacyPartnerId":"e3313d79-8351-11e1-99bb-15a7532ccabd","olmVendorId":"??","sbuId":"04","partnerName":"ADV MACHINING CONCEPTS IN","isActive":"1","isSingleApp":"0","partnerDba":[{"legacyPartnerDbaId":"cba7807d-d858-11e2-b507-e72995632c3e","partnerDbaName":"ADV MACHINERY CONCEPTS"}]}],"partnerSiteName":"","partnerSiteNumber":"0000104279-0001","isPrimarySite":"1","isActive":"1","address1":"4530 WADSWORTH RD","address2":"","address3":"","address4":"ID J5729","city":"DAYTON","county":"MONTGOMERY","stateAbbr":"OH","postalCode":"45414-4226","countryCode":"US","telephone":"9372787337","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"c92c217a-7cdb-11e1-97ec-8d7ceef5ce5f","salesRepName":"Reardon, Catherine"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"db3306e2-7cd8-11e1-abe3-39d43db26246","salesRepName":"McGlone, Raymond"}],"salesSupportRepSecondary":[{"legacySalesSupportRepId":"53b89b1b-7cd9-11e1-909d-4fe73922db06","salesRepName":"Miller, Catharine"},{"legacySalesSupportRepId":"d179a199-7ccb-11e1-bc8c-a3e1d4db657e","salesRepName":"Brown, Teresa"},{"legacySalesSupportRepId":"0ba1891b-6d24-11df-a92b-91cdf4ae16be","salesRepName":"Debro, Susan"},{"legacySalesSupportRepId":"51e44e1c-3767-11df-abd1-115dc8e3baf3","salesRepName":"Friel, Jenifer"},{"legacySalesSupportRepId":"3dcc01e5-7ccf-11e1-97ec-8d7ceef5ce5f","salesRepName":"Gonzales, Linda"},{"legacySalesSupportRepId":"d8e6952a-7ccf-11e1-a40b-cbd2841a6e01","salesRepName":"Hart, Robert"},{"legacySalesSupportRepId":"b1b256f2-4c0f-11e0-afc5-4dc8982a07cd","salesRepName":"Hazewski, Catherine"},{"legacySalesSupportRepId":"15488650-7cd8-11e1-909d-4fe73922db06","salesRepName":"Karpinecz, Jennifer"},{"legacySalesSupportRepId":"d4c696b5-7cd8-11e1-97ec-8d7ceef5ce5f","salesRepName":"McGlone, Jeffrey"},{"legacySalesSupportRepId":"3f99f715-cd8a-11df-9108-854a75c77af6","salesRepName":"Middleton, Tracy"},{"legacySalesSupportRepId":"e499de3a-4697-11e0-9029-e987f8e4824e","salesRepName":"Steger, Ryan"},{"legacySalesSupportRepId":"1b4c1df3-7cdf-11e1-97ec-8d7ceef5ce5f","salesRepName":"White, Michael"}],"program":[{"legacyProgramId":"edc32600-7cf0-11e1-909d-4fe73922db06","programNumber":"100101","programName":"MH_VENDOR INITIATIVE MACHINE TOOLS","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"63a7dd8d-7cd1-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"ecc2053d-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"49a9afa5-835d-11e1-b9ab-0130f2fd1ea0","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"49a9afa5-835d-11e1-b9ab-0130f2fd1ea0","partner":[{"legacyPartnerId":"4d2d3120-835d-11e1-b9ab-0130f2fd1ea0","olmVendorId":"??","sbuId":"05","partnerName":"ADV DATA & CONNECTIONS SOLUTI","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000128400-0001","isPrimarySite":"1","isActive":"1","address1":"60 RAVENSCROFT DR","address2":"","address3":"","address4":"ID I5713","city":"ASHEVILLE","county":"BUNCOMBE","stateAbbr":"NC","postalCode":"28801-3637","countryCode":"US","telephone":"8282858882","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"407c0270-7cd6-11e1-a40b-cbd2841a6e01","salesRepName":"Iavarone, Joseph"}],"salesRepSeondary":[{"legacySalesRepId":"d20518aa-3ea5-11e0-9cad-25ffa447ec02","salesRepName":"Ossolinski, Michael"}],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"535a59d8-7ccf-11e1-abe3-39d43db26246","salesRepName":"Grady, Kameka"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"c907717a-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100341","programName":"TF EQUIPMENTS TMM1","isActive":"1"},{"legacyProgramId":"d2de0f56-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100342","programName":"TF EQUIPMENTS","isActive":"1"},{"legacyProgramId":"6de50336-d829-11e2-944b-c77acc2e114f","programNumber":"100679","programName":"TF_FLEXPOD COMMERCIAL","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"7f57189d-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"Xoco Systems Capital Corporation"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"ebff5401-8365-11e1-99bb-15a7532ccabd","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"ebff5401-8365-11e1-99bb-15a7532ccabd","partner":[{"legacyPartnerId":"efad67ec-8365-11e1-99bb-15a7532ccabd","olmVendorId":"??","sbuId":"04","partnerName":"ADV POWER DISTRIBUTORS IN","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000132762-0001","isPrimarySite":"1","isActive":"1","address1":"PO BOX 520","address2":"","address3":"","address4":"ID J1088","city":"SUBLETTE","county":"HASKELL","stateAbbr":"KS","postalCode":"67877-0520","countryCode":"US","telephone":"6206752224","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[],"salesRepSeondary":[],"salesSupportRepPrimary":[],"salesSupportRepSecondary":[{"legacySalesSupportRepId":"53b89b1b-7cd9-11e1-909d-4fe73922db06","salesRepName":"Miller, Catharine"},{"legacySalesSupportRepId":"d179a199-7ccb-11e1-bc8c-a3e1d4db657e","salesRepName":"Brown, Teresa"},{"legacySalesSupportRepId":"0ba1891b-6d24-11df-a92b-91cdf4ae16be","salesRepName":"Debro, Susan"},{"legacySalesSupportRepId":"51e44e1c-3767-11df-abd1-115dc8e3baf3","salesRepName":"Friel, Jenifer"},{"legacySalesSupportRepId":"3dcc01e5-7ccf-11e1-97ec-8d7ceef5ce5f","salesRepName":"Gonzales, Linda"},{"legacySalesSupportRepId":"d8e6952a-7ccf-11e1-a40b-cbd2841a6e01","salesRepName":"Hart, Robert"},{"legacySalesSupportRepId":"b1b256f2-4c0f-11e0-afc5-4dc8982a07cd","salesRepName":"Hazewski, Catherine"},{"legacySalesSupportRepId":"15488650-7cd8-11e1-909d-4fe73922db06","salesRepName":"Karpinecz, Jennifer"},{"legacySalesSupportRepId":"d4c696b5-7cd8-11e1-97ec-8d7ceef5ce5f","salesRepName":"McGlone, Jeffrey"},{"legacySalesSupportRepId":"db3306e2-7cd8-11e1-abe3-39d43db26246","salesRepName":"McGlone, Raymond"},{"legacySalesSupportRepId":"3f99f715-cd8a-11df-9108-854a75c77af6","salesRepName":"Middleton, Tracy"},{"legacySalesSupportRepId":"e499de3a-4697-11e0-9029-e987f8e4824e","salesRepName":"Steger, Ryan"},{"legacySalesSupportRepId":"1b4c1df3-7cdf-11e1-97ec-8d7ceef5ce5f","salesRepName":"White, Michael"}],"program":[{"legacyProgramId":"2794a01e-7cfc-11e1-909d-4fe73922db06","programNumber":"100144","programName":"MH_DOOSAN INFRACORE AMERICA","isActive":"1"},{"legacyProgramId":"8ccc25fd-7cf0-11e1-909d-4fe73922db06","programNumber":"100092","programName":"MH_CNST","isActive":"1"},{"legacyProgramId":"cc7bedd9-7db2-11e1-a40b-cbd2841a6e01","programNumber":"100547","programName":"MH_DOOSAN RFLT","isActive":"0"}],"privateLabel":[{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."}]}},{"_index":"partnersite-index","_type":"dll","_id":"f9209af4-83dd-11e1-b221-d740d9250380","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"f9209af4-83dd-11e1-b221-d740d9250380","partner":[{"legacyPartnerId":"fd9113fd-83dd-11e1-b221-d740d9250380","olmVendorId":"??","sbuId":"05","partnerName":"ADV OFFICE SYSTEMS INC","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000157266-0003","isPrimarySite":"0","isActive":"1","address1":"2441 BEDFORD ST","address2":"","address3":"","address4":"ID T980","city":"JOHNSTOWN","county":"CAMBRIA","stateAbbr":"PA","postalCode":"15904-1440","countryCode":"US","telephone":"","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"5e16865b-edcc-11df-9b85-e91084c6a92e","salesRepName":"Frascella, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"6eb90e0f-ca66-11de-b16d-713108a20936","salesRepName":"Benedetto, Laurie"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"0e25e64b-a790-11e2-ad4e-67abe344c709","programNumber":"100667","programName":"OE_VENDOR 20/0","isActive":"1"},{"legacyProgramId":"9661bc0a-a791-11e2-ad4e-67abe344c709","programNumber":"100668","programName":"OE_VENDOR 25/0","isActive":"1"},{"legacyProgramId":"b71ea67f-a78e-11e2-ad4e-67abe344c709","programNumber":"100666","programName":"OE_VENDOR 33/33","isActive":"1"},{"legacyProgramId":"10be835b-7d97-11e1-97ec-8d7ceef5ce5f","programNumber":"100348","programName":"TF_INGRAM MICRO_NON VAR","isActive":"1"},{"legacyProgramId":"d3de35a8-7da0-11e1-97ec-8d7ceef5ce5f","programNumber":"100496","programName":"OE_RICOH","isActive":"0"},{"legacyProgramId":"8f72c193-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100465","programName":"OE_COMPUTER EQUIPMENT","isActive":"0"},{"legacyProgramId":"c36b32cb-7d00-11e1-909d-4fe73922db06","programNumber":"100249","programName":"OE_HARRIS 3 M","isActive":"0"},{"legacyProgramId":"341c14e2-7d95-11e1-97ec-8d7ceef5ce5f","programNumber":"100304","programName":"OE_VENDOR","isActive":"1"},{"legacyProgramId":"e07cc902-7d9c-11e1-97ec-8d7ceef5ce5f","programNumber":"100399","programName":"FI_VENDOR","isActive":"0"},{"legacyProgramId":"29161651-7da3-11e1-97ec-8d7ceef5ce5f","programNumber":"100518","programName":"OE_TOSHIBA INDEPENDENT DEALERS","isActive":"0"},{"legacyProgramId":"66b622d2-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100461","programName":"OE_CANON","isActive":"0"},{"legacyProgramId":"9c9796b6-a792-11e2-ad4e-67abe344c709","programNumber":"100669","programName":"OE_VENDOR 25/25","isActive":"1"},{"legacyProgramId":"2649c252-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100326","programName":"OE_VENDOR PUBLIC FINANCE","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"14521e93-7ce0-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"dc3cafda-d9fb-11e3-9a2a-613f9e74f6ac","privateLabelName":"BAUERNFEIND BUSINESS TECHNOLOGIES INC"},{"legacyPrivateLabelId":"ff6036a1-7cd1-11e1-8ab7-395b6e8a2f0b","privateLabelName":"KEYSTONE BUSINESS MACHINES, INC."}]}},{"_index":"partnersite-index","_type":"dll","_id":"f9213664-83dd-11e1-b221-d740d9250380","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"f9213664-83dd-11e1-b221-d740d9250380","partner":[{"legacyPartnerId":"fd9113fd-83dd-11e1-b221-d740d9250380","olmVendorId":"??","sbuId":"05","partnerName":"ADV OFFICE SYSTEMS INC","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000157266-0006","isPrimarySite":"0","isActive":"1","address1":"296 E MAIN ST","address2":"","address3":"","address4":"ID D5816","city":"BRANFORD","county":"NEW HAVEN","stateAbbr":"CT","postalCode":"06405-3104","countryCode":"US","telephone":"","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"5e16865b-edcc-11df-9b85-e91084c6a92e","salesRepName":"Frascella, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"6eb90e0f-ca66-11de-b16d-713108a20936","salesRepName":"Benedetto, Laurie"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"0e25e64b-a790-11e2-ad4e-67abe344c709","programNumber":"100667","programName":"OE_VENDOR 20/0","isActive":"1"},{"legacyProgramId":"9661bc0a-a791-11e2-ad4e-67abe344c709","programNumber":"100668","programName":"OE_VENDOR 25/0","isActive":"1"},{"legacyProgramId":"b71ea67f-a78e-11e2-ad4e-67abe344c709","programNumber":"100666","programName":"OE_VENDOR 33/33","isActive":"1"},{"legacyProgramId":"10be835b-7d97-11e1-97ec-8d7ceef5ce5f","programNumber":"100348","programName":"TF_INGRAM MICRO_NON VAR","isActive":"1"},{"legacyProgramId":"d3de35a8-7da0-11e1-97ec-8d7ceef5ce5f","programNumber":"100496","programName":"OE_RICOH","isActive":"0"},{"legacyProgramId":"8f72c193-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100465","programName":"OE_COMPUTER EQUIPMENT","isActive":"0"},{"legacyProgramId":"c36b32cb-7d00-11e1-909d-4fe73922db06","programNumber":"100249","programName":"OE_HARRIS 3 M","isActive":"0"},{"legacyProgramId":"341c14e2-7d95-11e1-97ec-8d7ceef5ce5f","programNumber":"100304","programName":"OE_VENDOR","isActive":"1"},{"legacyProgramId":"e07cc902-7d9c-11e1-97ec-8d7ceef5ce5f","programNumber":"100399","programName":"FI_VENDOR","isActive":"0"},{"legacyProgramId":"29161651-7da3-11e1-97ec-8d7ceef5ce5f","programNumber":"100518","programName":"OE_TOSHIBA INDEPENDENT DEALERS","isActive":"0"},{"legacyProgramId":"66b622d2-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100461","programName":"OE_CANON","isActive":"0"},{"legacyProgramId":"9c9796b6-a792-11e2-ad4e-67abe344c709","programNumber":"100669","programName":"OE_VENDOR 25/25","isActive":"1"},{"legacyProgramId":"2649c252-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100326","programName":"OE_VENDOR PUBLIC FINANCE","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"14521e93-7ce0-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"dc3cafda-d9fb-11e3-9a2a-613f9e74f6ac","privateLabelName":"BAUERNFEIND BUSINESS TECHNOLOGIES INC"},{"legacyPrivateLabelId":"ff6036a1-7cd1-11e1-8ab7-395b6e8a2f0b","privateLabelName":"KEYSTONE BUSINESS MACHINES, INC."}]}},{"_index":"partnersite-index","_type":"dll","_id":"f9215d91-83dd-11e1-b221-d740d9250380","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"f9215d91-83dd-11e1-b221-d740d9250380","partner":[{"legacyPartnerId":"fd9113fd-83dd-11e1-b221-d740d9250380","olmVendorId":"??","sbuId":"05","partnerName":"ADV OFFICE SYSTEMS INC","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000157266-0008","isPrimarySite":"0","isActive":"1","address1":"11434 INDUSTRIPLEX BLVD","address2":"","address3":"","address4":"ID G4656","city":"BATON ROUGE","county":"EAST BATON ROUGE","stateAbbr":"LA","postalCode":"70809-4230","countryCode":"US","telephone":"","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"5e16865b-edcc-11df-9b85-e91084c6a92e","salesRepName":"Frascella, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"6eb90e0f-ca66-11de-b16d-713108a20936","salesRepName":"Benedetto, Laurie"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"0e25e64b-a790-11e2-ad4e-67abe344c709","programNumber":"100667","programName":"OE_VENDOR 20/0","isActive":"1"},{"legacyProgramId":"9661bc0a-a791-11e2-ad4e-67abe344c709","programNumber":"100668","programName":"OE_VENDOR 25/0","isActive":"1"},{"legacyProgramId":"b71ea67f-a78e-11e2-ad4e-67abe344c709","programNumber":"100666","programName":"OE_VENDOR 33/33","isActive":"1"},{"legacyProgramId":"10be835b-7d97-11e1-97ec-8d7ceef5ce5f","programNumber":"100348","programName":"TF_INGRAM MICRO_NON VAR","isActive":"1"},{"legacyProgramId":"d3de35a8-7da0-11e1-97ec-8d7ceef5ce5f","programNumber":"100496","programName":"OE_RICOH","isActive":"0"},{"legacyProgramId":"8f72c193-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100465","programName":"OE_COMPUTER EQUIPMENT","isActive":"0"},{"legacyProgramId":"c36b32cb-7d00-11e1-909d-4fe73922db06","programNumber":"100249","programName":"OE_HARRIS 3 M","isActive":"0"},{"legacyProgramId":"341c14e2-7d95-11e1-97ec-8d7ceef5ce5f","programNumber":"100304","programName":"OE_VENDOR","isActive":"1"},{"legacyProgramId":"e07cc902-7d9c-11e1-97ec-8d7ceef5ce5f","programNumber":"100399","programName":"FI_VENDOR","isActive":"0"},{"legacyProgramId":"29161651-7da3-11e1-97ec-8d7ceef5ce5f","programNumber":"100518","programName":"OE_TOSHIBA INDEPENDENT DEALERS","isActive":"0"},{"legacyProgramId":"66b622d2-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100461","programName":"OE_CANON","isActive":"0"},{"legacyProgramId":"9c9796b6-a792-11e2-ad4e-67abe344c709","programNumber":"100669","programName":"OE_VENDOR 25/25","isActive":"1"},{"legacyProgramId":"2649c252-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100326","programName":"OE_VENDOR PUBLIC FINANCE","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"14521e93-7ce0-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"dc3cafda-d9fb-11e3-9a2a-613f9e74f6ac","privateLabelName":"BAUERNFEIND BUSINESS TECHNOLOGIES INC"},{"legacyPrivateLabelId":"ff6036a1-7cd1-11e1-8ab7-395b6e8a2f0b","privateLabelName":"KEYSTONE BUSINESS MACHINES, INC."}]}},{"_index":"partnersite-index","_type":"dll","_id":"f921f9e6-83dd-11e1-b221-d740d9250380","_score":4.3995514,"_source":{"legacySourceSystemId":"A2B","legacyPartnerSiteId":"f921f9e6-83dd-11e1-b221-d740d9250380","partner":[{"legacyPartnerId":"fd9113fd-83dd-11e1-b221-d740d9250380","olmVendorId":"??","sbuId":"05","partnerName":"ADV OFFICE SYSTEMS INC","isActive":"1","isSingleApp":"0","partnerDba":[]}],"partnerSiteName":"","partnerSiteNumber":"0000157266-0009","isPrimarySite":"0","isActive":"1","address1":"296 E MAIN ST","address2":"","address3":"","address4":"ID J9968","city":"BRANFORD","county":"NEW HAVEN","stateAbbr":"CT","postalCode":"06405-3104","countryCode":"US","telephone":"","email":"","paymentMethodCode":"??","isOriginating":"1","isDisqualified":"0","salesRepPrimary":[{"legacySalesRepId":"5e16865b-edcc-11df-9b85-e91084c6a92e","salesRepName":"Frascella, Michael"}],"salesRepSeondary":[],"salesSupportRepPrimary":[{"legacySalesSupportRepId":"6eb90e0f-ca66-11de-b16d-713108a20936","salesRepName":"Benedetto, Laurie"}],"salesSupportRepSecondary":[],"program":[{"legacyProgramId":"0e25e64b-a790-11e2-ad4e-67abe344c709","programNumber":"100667","programName":"OE_VENDOR 20/0","isActive":"1"},{"legacyProgramId":"9661bc0a-a791-11e2-ad4e-67abe344c709","programNumber":"100668","programName":"OE_VENDOR 25/0","isActive":"1"},{"legacyProgramId":"b71ea67f-a78e-11e2-ad4e-67abe344c709","programNumber":"100666","programName":"OE_VENDOR 33/33","isActive":"1"},{"legacyProgramId":"10be835b-7d97-11e1-97ec-8d7ceef5ce5f","programNumber":"100348","programName":"TF_INGRAM MICRO_NON VAR","isActive":"1"},{"legacyProgramId":"d3de35a8-7da0-11e1-97ec-8d7ceef5ce5f","programNumber":"100496","programName":"OE_RICOH","isActive":"0"},{"legacyProgramId":"8f72c193-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100465","programName":"OE_COMPUTER EQUIPMENT","isActive":"0"},{"legacyProgramId":"c36b32cb-7d00-11e1-909d-4fe73922db06","programNumber":"100249","programName":"OE_HARRIS 3 M","isActive":"0"},{"legacyProgramId":"341c14e2-7d95-11e1-97ec-8d7ceef5ce5f","programNumber":"100304","programName":"OE_VENDOR","isActive":"1"},{"legacyProgramId":"e07cc902-7d9c-11e1-97ec-8d7ceef5ce5f","programNumber":"100399","programName":"FI_VENDOR","isActive":"0"},{"legacyProgramId":"29161651-7da3-11e1-97ec-8d7ceef5ce5f","programNumber":"100518","programName":"OE_TOSHIBA INDEPENDENT DEALERS","isActive":"0"},{"legacyProgramId":"66b622d2-7d9f-11e1-97ec-8d7ceef5ce5f","programNumber":"100461","programName":"OE_CANON","isActive":"0"},{"legacyProgramId":"9c9796b6-a792-11e2-ad4e-67abe344c709","programNumber":"100669","programName":"OE_VENDOR 25/25","isActive":"1"},{"legacyProgramId":"2649c252-7d96-11e1-97ec-8d7ceef5ce5f","programNumber":"100326","programName":"OE_VENDOR PUBLIC FINANCE","isActive":"1"}],"privateLabel":[{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"14521e93-7ce0-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"0ad59037-7cd2-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY FINANCIAL SERVICES"},{"legacyPrivateLabelId":"3ba79ae3-9c07-11e2-b20a-7df886e59b8d","privateLabelName":"KBA DOCUSYS INC"},{"legacyPrivateLabelId":"7a7b5644-7cdf-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO OFFICE SYSTEMS, INC"},{"legacyPrivateLabelId":"8b6556d7-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"COECO FINANCIAL SERVICES"},{"legacyPrivateLabelId":"bb8fa912-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY Financial Services, Inc."},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"c78926d2-7cd8-11e1-8ab7-395b6e8a2f0b","privateLabelName":"SOME COMPANY PUBLIC FINANCE"},{"legacyPrivateLabelId":"dc3cafda-d9fb-11e3-9a2a-613f9e74f6ac","privateLabelName":"BAUERNFEIND BUSINESS TECHNOLOGIES INC"},{"legacyPrivateLabelId":"ff6036a1-7cd1-11e1-8ab7-395b6e8a2f0b","privateLabelName":"KEYSTONE BUSINESS MACHINES, INC."}]}}]}}
The PDN article Kevin mentioned seems to indicate that this issue was fixed in 7.1.8. I confirmed the same by looking at the 7.1.7 SE/SR details. So, it is strange that you are seeing this problem in 7.1.8. Anyway, I just tested this on the latest version of Pega and the issue isn't reproducible. We made some fixes in the recent past and this must have been one of them. I suggest you raise an SR for further investigation against 7.1.8.
Hi Sandeep Roy
Were you able to open a SR as per Praneeth Purighalla request? If you were, please let us know the SR so that we can track it for you within this thread.
Thanks!
Vidyaranjan A V | Online Community Moderator | Pegasystems Inc.
SR-A17857 has been submitted for this.
... and SE-26048 has been sun-off of that ticket requesting port of BUG-216001 back to 7.1.8.
this issue was found in 7.1.8 and fixed in 7.2 release as BUG-216601
