infosys
Last activity: 18 Jun 2018 12:06 EDT
need to remove run time tools top bar
Created an application in 7.3.1 . when i am running the application, on the case manager portal top i am getting the run time tools top bar ( pzRuntimeToolsTopBar) . I want to remove that from the portal however, not finding a way to remove it. Please suggest a approach to do it.
Can you check the following?
First verify the access role of your users and make sure that they do not have the agile workbench or the live UI privilege - end users should not have this functionality turned on.
If you want to disable the runtime toolbar completely in your application, you can save the when pyEnableRuntimeToolbar and set the when rule to false in your application.
Susan
