Need Info on Upgrading Pega v7.3 to Pega v7.4
We are currently using a Pega v7.3 Instance and we have installed Pega RRipples in the instance. Pega RRipples will not be available from Pega v7.4 as of now. So, if I try to upgrade my Pega instance from Pega v7.3 to v7.4, Will my upgrade go fine or is there any chance of upgrade failure?
Can anyone please help.
Upgrade should not have any impact, please ensure RRipples is disabled before you start upgrade [use DSS config/rripples/enable=false and disable rripples agents].
Also note that RRipples exchange component was tested only till Pega 7.2.x.
