Need help on deployment and running of automation in production server
We are implementing rpa automation which Will check health of applications every hour for operations.We have few questions on deployment and running automation.
Q1) Automation currently we are working are non pega applications.We are planning to deploy bots in production server not VM.Currently we are planning 5 bots because each will have different process and different applications they will run in different intervals.How many bots can we run on single runtime application? If we can run only one bit for one runtime then how can we make our solution to accommodate other bots.
Q2) Without use of runtime application can we run our bots.If yes,can you provide us some guidance on that.
Q 3) Can we Deploy our automation in Unix server box.If yes, Can you provide us some guidance on that.
Q 4) How to run pega robotic automation in Unix server box and how to schedule those bots.
