Last activity: 23 Jun 2025 17:19 EDT
Multiple promoted filters using the same property
Business Context: My client needs to filter case submissions based on an Effective Date property. They want to see submissions that fall within a specific timeframe: from 7 days ago through the next 120 days (essentially a rolling window that covers recent past submissions and upcoming future submissions).
Current Working Solution: I can successfully achieve this filtering using the Advanced Filter feature in the list view, where I can set the Effective Date property to show "Last 7 Days to Next 120 Days" in a single filter configuration.
Desired Outcome: The client would like this filtering capability to be available as promoted filters so all users can easily access these date ranges without having to configure advanced filters themselves.
Technical Challenge: When I attempt to create promoted filters for this use case, I encounter a limitation: I cannot create two separate promoted filters that both use the same property (Effective Date). Ideally, I would create:
- Filter 1: "Last 7 days" using Effective Date
- Filter 2: "Next 120 days" using Effective Date
Question: Is there a supported way to create multiple promoted filters that reference the same property, or is there an alternative approach to provide users with easy access to this combined date range filtering functionality?
