Knowledge Experts SA
FR
Last activity: 4 Mar 2016 11:09 EST
Moving flow action behaviour error
We have an assignment with 3 flow actions possible like below.
When we run it and choose to execute test1 flow action, the test3 is executed like below
We got the same error if we execute the test2 flow action. We change the likelihood with different conbination and we have always an error.
How can we fix it.
Wassim Jrad
Does "no form has been added" mean you haven't defined the actual flow action rule ? I suggest trying the following to see if it helps clarify the issue:
1) Have all your paths lead to the end shape instead of merely stopping.
2) Make sure your flow is not set to draft mode, in case that reveals some errors that help resolve the issue.
3) Define all flow action screens to have some unique text so you can distinguish between them.
/Eric
