Move back from screen flow to other flow
I have 2 processes in stage - to simplify flow A and B. Each of them is ScreenFlow. I have requirement to move back form B to A using button. When I've added on click action activity "pxChangeStage" it move it back, but starting from Review mode. I need to have it in Perform. Business requirement it to have this flows separated. "Run on re-entry" is enabled. May I kindly ask You for help with this issue?
Regards
You can use below javascript function to change stage.
"pega.ui.HarnessActions.changeStage"
Let us know if this helps.
