Deutsche Bank AG
DE
Last activity: 15 Feb 2018 6:12 EST
MARKETING DIRECTOR - segment creation is causing unique constraint violation in table STORED_FLD_TEMPL
Hi together,
we are using PEGA MARKETING DIRECTOR 6.6. Our business users are facing the issue that the creation of a new segment is causing an error. When checking the user logs we can see the oracle error UNIQUE CONSTRAINT VIOLATED for table STORED_FLD_TEMPL.
When checking the table based on the primary key it seems that the application has taken an existing SEG_ID for the new segment.
We have discovered a workaround for this in a way that business users can create a copy of an existing segment. This is working for them and a new valid SEG_ID is created. After doing that the CREATE SEGMENT option is working from scratch also.
Anyways this behaviour is unsatisfying and needs to be solved.
Thank you in advance for your support.
***Updated by moderator: Lochan to tag SR***
