Cisco Systems
Posted: September 25, 2017
Last activity: September 27, 2017
Last activity: 27 Sep 2017 12:24 EDT
Mapping of Incoming Response from a Connect-REST failed
We are trying a consume a REST Service through connect-REST, Whenever we are sending a huge payload in the Request, we are getting the below response and error:
When the same request(with huge payload) is sent from a REST client like POSTMAN, we are getting the right JSON response.
Response:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>414 Request-URI Too Large</title> </head><body> <h1>Request-URI Too Large</h1> <p>The requested URL's length exceeds the capacity limit for this server.
</p> </body></html>
Error:
** Error mapping incoming response to <.ResponsePropertyName>: org.codehaus.jackson.JsonParseException: Unexpected character ('<' (code 60)): expected a valid value (number, String, array, object, 'true', 'false' or 'null')
Response:
</p> </body></html>
Error:
Show More
Response:
</p> </body></html>
Error:
at [Source: java.io.StringReader@2f7857d5; line: 1, column: 2]
However when the Request payload is small, The incoming response is rightly mapped and we can find the same on Clipboard.
We found the following solution on PDN and this didn't seem to work:
https://community.pega.com/support/support-articles/exception-thrown-incoming-response-connect-rest
The following error was seen even after implementing the work-around mentioned in the link:
</p> </body></html>
Response:
</p> </body></html>
Error:
</p> </body></html>
Thanks in Advance!
Show Less
