CGI
SE
Last activity: 26 Jul 2019 6:46 EDT
Getting 404 response for CONNECT-REST Calls
Getting 404 response to Connect-REST calls and API team has confirmed that nothing has been registered at their end.
For debugging purpose ,REST class has been set to debug mode , we see request is forming correct but no clue for failure. it's occuring intermittently . How do we ensure that connect call has been sent from Pega ? I
appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Mapping response parameters to clipboard
2019-07-23 07:50:27,748 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) INFO appl.Org.com|10.32.24.32|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Starting remote service invocation...
2019-07-23 07:50:27,754 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) INFO appl.Org.com|10.32.24.32|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - HTTP Request: GET https://api.org:123/RESTv3/api/v3.0/Test/Person/XXXX-XXXX/Volume
2019-07-23 07:50:27,754 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) INFO appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Adding outbound header values to HTTP request
2019-07-23 07:50:27,754 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) DEBUG appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Setting header "Authorization" to value ""
2019-07-23 07:50:27,754 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) DEBUG appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Avoiding setting request body as HTTP method is GET
------------------HTTP REQUEST CONTENTS------------------GET /RESTv3/api/v3.0/Test/Person/XXXX-XXXX/Volume HTTP/1.1
Request Headers: {}
Request Message Data: N/A (this is a GET request)
----------------END HTTP REQUEST CONTENTS----------------
2019-07-23 07:50:27,800 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) INFO appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - HTTP Status code: 404 Not Found
2019-07-23 07:50:27,800 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) DEBUG appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX -
------------------HTTP RESPONSE CONTENTS------------------
Response Headers:
Cache-Control: must-revalidate,no-cache,no-store
Content-Length: 269
Content-Type: text/html;charset=ISO-8859-1
Response Message Data: 269 bytes received
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1"/>
<title>Error 404 Not Found</title>
</head>
<body><div style="font-family:Arial,Helvetica,sans-serif;"><h2>HTTP ERROR 404</h2>
Reason:
<pre> Not Found</pre></div>
</body>
</html>
----------------END HTTP RESPONSE CONTENTS----------------
2019-07-23 07:50:27,800 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) DEBUG appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Reading inbound header values from HTTP response
2019-07-23 07:50:27,800 [2.10.12-443-exec-113] [TABTHREAD0] [ ] [ APP:01.01.01] ( connect.rest.RESTConnector) INFO appl.Org.com|127.0.0.1|Rule-Connect-REST.XXXXXXXX XXXX-XXXX - Reading HTTP response message data
