Log-Usage rule execution entries only showing stream rules
I'm trying to extract rule execution statistics from Log-RuleUsage and Log-RuleUsage-Details snapshot instances. This is documented at https://docs.pega.com/system-administration/86/rule-usage-snapshots but results I'm seeing only seem to include stream related rules such as Flow Actions or HTML rules and not the advertised "any rule that is converted to Java at assembly time". Actually the exact opposite seems to be true in reality.
The documentation examples seem to suggest that all Java generated rules should captured:
DECISIONTREE.RA_DECLARE_DECISIONTREE_RULE_PARSE_DELIMITED_GETPROMPTKEY_362AD3D39240B644A4CFBE58EA5DA52E RA_ACTIVITY_DATA_ADMIN_OPERATOR_ID_SAVEDEVELOPERPREFERENCESXML_0C4D9291362765E0470388C76C1FD527
RA_HTML_FRAGMENT_SMARTPROMPT_NOINPUT_1EF7F65A6B1B426D7A6E5A270B8DF4DD!
I would be interested to learn whether anyone else experienced a similar result?
