leginwincapture.cab installations when using the designer on Internet Explore Browser
Solution was:
Nathan,
Just to expand on your posted solution - this prompt is because IE is trying to install ActiveX controls - This is why it requires admin privileges and explains why you only need to do this once (it only needs to authenticate to install the controls - not run them).
- Though if you ever access another Pega application with a higher version of those controls, it will prompt you again like this (to install the newer controls).
Cheers!
