JVM going down due to stuck thread (Pega 7.1.8)
We are seeing our production JVM going down due to the below error :-
We are under the assumption that this is exhausting the available threads thereby causing the system to go down. Any idea what might be causing the issue ?
Error logs :------------------------------------------------------------
####<Mar 7, 2016 11:18:53 AM PST> <Error> <WebLogicServer> <slcpegaapp1a> <slcpegaapp1a_unify_L1_1> <[ACTIVE] ExecuteThread: '65' for queue: 'weblogic.kernel.Default (self-tuning)'> <<WLS Kernel>> <> <> <1457378333095> <BEA-000337> <[STUCK] ExecuteThread: '59' for queue: 'weblogic.kernel.Default (self-tuning)' has been busy for "682" seconds working on the request "Workmanager: default, Version: 0, Scheduled=true, Started=true, Started time: 682087 ms
", which is more than the configured time (StuckThreadMaxTime) of "600" seconds in "server-failure-trigger". Stack trace:
java.util.HashMap.hash(HashMap.java:366)
java.util.HashMap.getEntry(HashMap.java:466)
java.util.HashMap.get(HashMap.java:421)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.setTopLevelPageCache(ClipboardPageImpl.java:2533)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.setClassName(ClipboardPageImpl.java:863)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.put(ClipboardPageImpl.java:2162)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.put(ClipboardPageImpl.java:1917)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.put(ClipboardPageImpl.java:1907)
com.pega.pegarules.data.internal.clipboard.ClipboardPageBase.put(ClipboardPageBase.java:1155)
com.pega.pegarules.data.internal.clipboard.DirectStreamContainer.expandToProperty(DirectStreamContainer.java:543)
com.pega.pegarules.data.internal.clipboard.DirectStreamContainer.expandAllToProperties(DirectStreamContainer.java:406)
com.pega.pegarules.data.internal.clipboard.ClipboardPageImpl.expandAll(ClipboardPageImpl.java:1146)
com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.setMiscellaneousProperties(ReadOnlyDataPageHandler.java:282)
com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.loadDataPage(ReadOnlyDataPageHandler.java:228)
com.pega.pegarules.session.internal.mgmt.base.handler.ReadOnlyDataPageHandler.findDataPage(ReadOnlyDataPageHandler.java:430)
com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.findDataPageInCurrentDir(AbstractPageDirectory.java:920)
com.pega.pegarules.session.internal.mgmt.base.AbstractPageDirectory.getDirectPage(AbstractPageDirectory.java:713)
com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getDirectPage(ThreadPageDir.java:473)
com.pega.pegarules.session.internal.mgmt.base.ThreadPageDir.getPage(ThreadPageDir.java:431)
com.pega.pegarules.session.internal.mgmt.PRThreadImpl.getPage(PRThreadImpl.java:539)
com.pega.pegarules.session.internal.mgmt.Executable.findPage(Executable.java:2081)
com.pega.pegarules.session.internal.mgmt.Executable.findPage(Executable.java:2034)
com.pega.pegarules.session.internal.mgmt.Executable.findPage(Executable.java:2016)
com.pega.pegarules.session.internal.mgmt.authentication.Authentication.getSecuritySettingDeclarePage(Authentication.java:652)
com.pega.pegarules.session.internal.mgmt.authentication.Authentication.getSecuritySettingAsBoolean(Authentication.java:661)
com.pega.pegarules.session.internal.mgmt.authentication.Authentication.doAuthentication(Authentication.java:574)
com.pega.pegarules.integration.engine.internal.services.ServiceAPI.handleAuthentication(ServiceAPI.java:1577)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.activityExecutionProlog(EngineAPI.java:548)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequestInner(EngineAPI.java:383)
sun.reflect.GeneratedMethodAccessor361.invoke(Unknown Source)
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
java.lang.reflect.Method.invoke(Method.java:606)
com.pega.pegarules.session.internal.PRSessionProviderImpl.performTargetActionWithLock(PRSessionProviderImpl.java:1270)
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:1008)
com.pega.pegarules.session.internal.PRSessionProviderImpl.doWithRequestorLocked(PRSessionProviderImpl.java:841)
com.pega.pegarules.session.external.engineinterface.service.EngineAPI.processRequest(EngineAPI.java:331)
com.pega.pegarules.integration.engine.internal.services.soap.SOAPService.invoke(SOAPService.java:579)
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl._invokeEngine_privact(EngineImpl.java:315)
com.pega.pegarules.session.internal.engineinterface.etier.impl.EngineImpl.invokeEngine(EngineImpl.java:263)
com.pega.pegarules.session.internal.engineinterface.etier.ejb.EngineBean.invokeEngine(EngineBean.java:225)
sun.reflect.GeneratedMethodAccessor256.invoke(Unknown Source)
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethod(PRBootstrap.java:367)
com.pega.pegarules.internal.bootstrap.PRBootstrap.invokeMethodPropagatingThrowable(PRBootstrap.java:408)
com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingThrowable(AppServerBridgeToPega.java:223)
com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethodPropagatingException(AppServerBridgeToPega.java:245)
com.pega.pegarules.internal.etier.ejb.EngineBeanBoot.invokeEngine(EngineBeanBoot.java:168)
com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.__WL_invoke(Unknown Source)
weblogic.ejb.container.internal.SessionLocalMethodInvoker.invoke(SessionLocalMethodInvoker.java:33)
com.pega.pegarules.internal.etier.ejb.EngineBMT_h449u3_ELOImpl.invokeEngine(Unknown Source)
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngineInner(JNDIEnvironment.java:278)
com.pega.pegarules.priv.context.JNDIEnvironment.invokeEngine(JNDIEnvironment.java:223)
com.pega.pegarules.web.impl.WebStandardImpl.makeEtierRequest(WebStandardImpl.java:574)
com.pega.pegarules.web.impl.WebStandardImpl.doPost(WebStandardImpl.java:374)
sun.reflect.GeneratedMethodAccessor426.invoke(Unknown Source)
com.pega.pegarules.boot.internal.extbridge.AppServerBridgeToPega.invokeMethod(AppServerBridgeToPega.java:272)
com.pega.pegarules.internal.web.servlet.WebStandardBoot.doPost(WebStandardBoot.java:121)
javax.servlet.http.HttpServlet.service(HttpServlet.java:751)
javax.servlet.http.HttpServlet.service(HttpServlet.java:844)
weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:280)
weblogic.servlet.internal.StubSecurityHelper$ServletServiceAction.run(StubSecurityHelper.java:254)
weblogic.servlet.internal.StubSecurityHelper.invokeServlet(StubSecurityHelper.java:136)
weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:346)
weblogic.servlet.internal.ServletStubImpl.execute(ServletStubImpl.java:243)
weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.wrapRun(WebAppServletContext.java:3432)
weblogic.servlet.internal.WebAppServletContext$ServletInvocationAction.run(WebAppServletContext.java:3402)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(AuthenticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(SecurityManager.java:120)
weblogic.servlet.provider.WlsSubjectHandle.run(WlsSubjectHandle.java:57)
weblogic.servlet.internal.WebAppServletContext.doSecuredExecute(WebAppServletContext.java:2285)
weblogic.servlet.internal.WebAppServletContext.securedExecute(WebAppServletContext.java:2201)
weblogic.servlet.internal.WebAppServletContext.execute(WebAppServletContext.java:2179)
weblogic.servlet.internal.ServletRequestImpl.run(ServletRequestImpl.java:1575)
weblogic.servlet.provider.ContainerSupportProviderImpl$WlsRequestExecutor.run(ContainerSupportProviderImpl.java:255)
weblogic.work.ExecuteThread.execute(ExecuteThread.java:311)
weblogic.work.ExecuteThread.run(ExecuteThread.java:263)
