Java error while installing Pega Platform 8.72
HI, Pega Support.
I encountered Java error while installing Pega Platform 8.72 by executing "./install.sh"
The error message is below.
BUILD FAILED /opt/pega/scripts/setupDatabase.xml:465: The following error occurred while executing this line: /opt/pega/scripts/setupDatabase.xml:2347: Java returned: 1
For Your Information, Environment Variables are below
CATALINA_HOME=/opt/tomcat9/ JAVA_HOME=/usr/lib/jvm/java-11-openjdk-11.0.16.0.8-1.el8_6.x86_64 JRE_HOME=/usr/lib/jvm/jre
setupdata.properties settings are blow (just ojdbc part of the settings)
pega.jdbc.driver.jar=/opt/tomcat9/lib/ojdbc8.jar pega.jdbc.driver.class=oracle.jdbc.OracleDriver
I would appreciate if you could advise me for finding solutions or any root cause.
I'm in hurry to set this server for our project, so please inform us as soon as possible.
***Edited by Moderator Marije to add Support Case Details;***
