Issues calling the flow PegaAccel-Task-InviteUser.pyInviteUser
We have a requirement to to send a DWA invitation to an external user, get the user activated and set password.
We have found a flow that does exactly what we need, called pyInviteUser under Class PegaAccel-Task-InviteUser.
We have tried calling the flow by setting the below action on the Click of a button
Approach1) calling activity that sets the parameters of the flow pyInviteUser and then calls the activity Work-.startFlow.
Approach2) calling 'Create Work' as can be seen in the below screenshot
In both cases, we are getting the below warning: (PegaAccel-Task-InviteUser)ProblemFlow pzInviteUser ASSIGNMENT63 Party Collaborator is missing from Work Item although the parameter 'Party' is already set in the flow pyInviteUser in the '' assignemnet.
Also we are getting an error in the activity AddAssign on step 4 when trying to open the operator :
Unable to open an instance using the given inputs: pxObjClass = "Data-Admin-Operator-ID", pyUserIdentifier = "Administrator@MX" |
Is there any ideas on how to overcome those errors ?
Or is there another approach to call the flow pyInviteUser that does exacly what we need ?
Thank you in advance,
Mariane
Hello Eric,
Thank you for your reply.
We managed to fix the issue by editing the outbound email and by setting the below parameters:
.pyWorkParty("Collaborator").pyUserName, .pyWorkParty("Collaborator").pyUserIdentifier and .pyWorkParty("Collaborator").pyEmail1
Mariane
