Accenture Services Pvt Ltd
Issue while upgrade Pega Government Platform 7.16 to 7.21
hi,
We have a environment on PRPC7.1.9 with PGP7.16 running on WAS7.0.0.25. Now we upgraded that to PRPC7.2.1 with WAS8.5.5.8.
While upgrading the framework from PGP7.16 to 7.21 we are getting issue and not able to import the jar file. Please find the log below.
Also we didn't find any upgrade document for PGP7.21 framework in PDN.
current cursor size is 10000 and process 500. But still same issue.
Could anyone please suggest.
Caused by:
com.pega.pegarules.pub.database.DatabaseException: There was a problem getting a list: code: 1000 SQLState: 72000 Message: ORA-01000: maximum open cursors exceeded
ORA-06512: at "PRPCDATA.SPPR_SYS_RESERVEQUEUEITEM_B", line 152
ORA-06512: at line 1
DatabaseException caused by prior exception: java.sql.SQLException: ORA-01000: maximum open cursors exceeded
| SQL Code: 1000 | SQL State: 72000
SQL: {call PRPCDATA.sppr_sys_reservequeueitem_b ( ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) }
Caused by SQL Problems.
hi,
Caused by:
Problem #1, SQLState 72000, Error code 1000: java.sql.SQLException: ORA-01000: maximum open cursors exceeded
at com.pega.pegarules.data.internal.access.ExceptionInformation.createExceptionDueToDBFailure(ExceptionInformation.java:262)
at com.pega.pegarules.data.internal.access.DatabaseImpl.list(DatabaseImpl.java:4844)
at com.pega.pegarules.data.internal.access.DBQueryExecutor.executeRDB(DBQueryExecutor.java:115)
at com.pega.pegarules.data.internal.access.DBQueryExecutor.executeRDB(DBQueryExecutor.java:66)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:5210)
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeRDB(DatabaseImpl.java:5190)
at com.pega.pegarules.session.internal.async.agent.QueueManagerImpl$QueueIteratorImpl.next(QueueManagerImpl.java:2008)
[10/20/16 8:20:04:086 EST] 0000005d SystemOut O 2016-10-20 08:20:03,462 [.PRPCWorkManager : 0] [ STANDARD] [ shared] [ PegaRULES:07.10] (ternal.util.SchemaImporterTool) ERROR [email protected] - Unable to make schema change because database name is null: code: <none> SQLState: <none> Message: <none>
com.pega.pegarules.pub.database.DatabaseException: Unable to make schema change because database name is null: code: <none> SQLState: <none> Message: <none>
at com.pega.pegarules.data.internal.access.DatabaseImpl.executeDBSchemaDDL(DatabaseImpl.java:5749)
[10/20/16 8:20:04:086 EST] 0000005d SystemOut O 2016-10-20 08:20:03,478 [.PRPCWorkManager : 0] [ STANDARD] [ shared] [ PegaRULES:07.10] (ernal.async.BatchRequestorTask) ERROR [email protected] - Batch activity "Rule-.PegaRULESMove_Zip_To_DB" threw:
com.pega.pegarules.pub.PRRuntimeError: PRRuntimeError
at com.pega.pegarules.session.internal.mgmt.base.ThreadRunner.
***Updated by moderator: Lochan to move from PSC to Pega Upgrade Center***
