    Tech Mahindra
Last activity: 25 Jun 2018 5:16 EDT
Issue in executing prpcServiceUtils
Dear Team,
Our Infra team had configured Jenkins job to export pega application.
However they are facing issue when they have executed the below command
$PEGA_HOME/scripts/utils/prpcServiceUtils.sh export --connPropFile
it complains about parameter -Dprpcserviceutils.connection.filepath being null. please find the logs below
Started by user admin
[EnvInject] - Loading node environment variables.
[EnvInject] - Preparing an environment for the build.
[EnvInject] - Keeping Jenkins system variables.
[EnvInject] - Keeping Jenkins build variables.
[EnvInject] - Injecting as environment variables the properties content
TargetUser=
SystemName=$BUILD_TAG
SourcePassword=XXXXXXXXXX
SourceHost= Proprietary information hidden
Inject=environment variables to the build process=Properties Content
TargetHost=
Source=Code Management=None
SourceUser=PegaAdmin
Dear Team,
TargetUser=
TargetHost=
[EnvInject] - Variables injected successfully.
[EnvInject] - Injecting contributions.
Building in workspace /var/lib/jenkins/workspace/AS_PEGA_EXPORT
[AS_PEGA_EXPORT] $ /bin/sh -xe /tmp/jenkins8976609299633357842.sh
+ export ANT_HOME=/var/lib/ant/apache-ant-1.9.10
+ ANT_HOME=/var/lib/ant/apache-ant-1.9.10
+ export PATH=/sbin:/usr/sbin:/bin:/usr/bin:/var/lib/ant/apache-ant-1.9.10/bin
+ PATH=/sbin:/usr/sbin:/bin:/usr/bin:/var/lib/ant/apache-ant-1.9.10/bin
+ export JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk- Proprietary information hidden.x86_64
+ JAVA_HOME=/usr/lib/jvm/java-1.7.0-openjdk- Proprietary information hidden.x86_64
+ /var/lib/ant/apache-ant-1.9.10/bin/ant -file /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/samples/jenkins/Jenkins-build.xml -DproductVersion=07.21 -DproductName=PegaPDFS exportprops
Buildfile: /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/samples/jenkins/Jenkins-build.xml
exportprops:
[propertyfile] Creating new property file: /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/jenkins-AS_PEGA_EXPORT-44_export.properties
BUILD SUCCESSFUL
Total time: 0 seconds
+ echo 'Done with Stage-0'
Done with Stage-0
+ echo '**************************************'
+ echo 'TEST TEST'
TEST TEST
+ /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtils.sh export --connPropFile
run eval "/var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/../bin/ant" -Dprpcserviceutils.connection.filepath="" -Dprpc.service.util.action=export -Dlogfile.timestamp=Mar-21-2018-03-00-52 -f "/var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml" performOperation 2>&1 | tee /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/logs/CLI-prpcServiceUtils-log-Mar-21-2018-03-00-52.log
run eval /var/lib/ant/apache-ant-1.9.10/bin/ant -Dprpcserviceutils.connection.filepath="" -Dprpc.service.util.action=export -Dlogfile.timestamp=Mar-21-2018-03-00-52 -f "/var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml" performOperation 2>&1 | tee /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/logs/CLI-prpcServiceUtils-log-Mar-21-2018-03-00-52.log
Buildfile: /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml
[echo] *** JVM Arguments -Xmx1280m -XX:MaxPermSize=512m ***
-init:
[echo] ******************************************************************
[echo] Build date : $
{pegaBuildDate.value}
[echo] Pega7 platform version : $
{specificationVersion.value}
[delete] Deleting directory /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/generated
[mkdir] Created dir: /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/generated
[pega:propertyparser] Reading Properties from: /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtils.properties
[pega:propertyparser] getstatus.jobID=
[pega:propertyparser] hotfix.async=true
[pega:propertyparser] expose.includeDescendents=true
[pega:propertyparser] export.async=true
[pega:propertyparser] expose.async=true
[pega:propertyparser] expose.excludedClasses=
[pega:propertyparser] import.commitRate=100
[pega:propertyparser] export.productName=
[pega:propertyparser] export.branchAppContext=
[pega:propertyparser] expose.commitRate=100
[pega:propertyparser] import.existingInstances=skip
[pega:propertyparser] user.temp.dir=C:/pega_temp
[pega:propertyparser] expose.reindex=true
[pega:propertyparser] hotfix.operation=
[pega:propertyparser] expose.excludeDescendents=true
[pega:propertyparser] updateAccessGroup.applicationName=
[pega:propertyparser] import.nofailonerror=false
[pega:propertyparser] pega.rest.proxy.password=*****
[pega:propertyparser] import.codesetVersion=06-01-01
[pega:propertyparser] export.applicationVersion=
[pega:propertyparser] pega.rest.proxy.username=
[pega:propertyparser] expose.includedClasses=
[pega:propertyparser] rollback.action=SystemRollback
[pega:propertyparser] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash>
[pega:propertyparser] updateAccessGroup.applicationVersion=
[pega:propertyparser] expose.startKey=
[pega:propertyparser] expose.reindexType=nonpega
[pega:propertyparser] import.codesetName=Customer
[pega:propertyparser] manageRestorePoints.restorePointLabel=
[pega:propertyparser] import.async=true
[pega:propertyparser] pega.rest.password=*****
[pega:propertyparser] hotfix.force=false
[pega:propertyparser] import.compileLibraries=true
[pega:propertyparser] rollback.restorePointName=
[pega:propertyparser] import.allowImportWithMissingDependencies=false
[pega:propertyparser] export.productVersion=
[pega:propertyparser] pega.rest.username=
[pega:propertyparser] rollback.async=true
[pega:propertyparser] export.branchName=
[pega:propertyparser] getstatus.operationName=
[pega:propertyparser] expose.endDate=
[pega:propertyparser] import.preserveOrder=true
[pega:propertyparser] rollback.downloadLogToFile=true
[pega:propertyparser] pega.rest.proxy.port=
[pega:propertyparser] pega.rest.proxy.workstation=
[pega:propertyparser] expose.endKey=
[pega:propertyparser] hotfix.dlFilePath=
[pega:propertyparser] import.archive.path=
[pega:propertyparser] updateAccessGroup.groupList=
[pega:propertyparser] manageRestorePoints.restorePointName=
[pega:propertyparser] export.archiveName=
[pega:propertyparser] import.mode=import
[pega:propertyparser] expose.startDate=
[pega:propertyparser] hotfix.bypassSchema=false
[pega:propertyparser] manageTrackedData.operation=
[pega:propertyparser] expose.numOfThreads=1
[pega:propertyparser] hotfix.catalogPath=
[pega:propertyparser] manageRestorePoints.action=
[pega:propertyparser] import.skipBackup=false
[pega:propertyparser] pega.rest.proxy.domain=
[pega:propertyparser] export.applicationName=
[pega:propertyparser] pega.rest.response.type=json
[pega:propertyparser] pega.rest.proxy.host=
[mkdir] Created dir: /tmp/PegaInstallTemp-21-March-2018-03.00.53
[pega:hasenoughspace] Found 5859864KB of free space on '/tmp'
-processInstances:
[echo] Performing export on multiple instance(s)
[pega:echoargline] arg line : -action export -propFileDir /var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/generated -poolSize $
{prpcserviceutils.pool.size}
-requestTimeOut $
{prpcserviceutils.request.timeout}
-tempDir /tmp/PegaInstallTemp-21-March-2018-03.00.53 -artifactsDir logs
[echo] Reading connection information from
[pega:propertyfilegenerator] pega.rest.server.url=http://<host name>:<port number>/<context>/PRRestService/<tenant url hash>
[pega:propertyfilegenerator] pega.rest.username=
[pega:propertyfilegenerator] pega.rest.password=*****
[pega:propertyfilegenerator] pega.rest.proxy.host=
[pega:propertyfilegenerator] pega.rest.proxy.port=
[pega:propertyfilegenerator] pega.rest.proxy.username=
[pega:propertyfilegenerator] pega.rest.proxy.password=*****
[pega:propertyfilegenerator] pega.rest.proxy.domain=
[pega:propertyfilegenerator] pega.rest.proxy.workstation=
[pega:propertyfilegenerator] pega.rest.response.type=json
[pega:propertyfilegenerator] user.temp.dir=C:/pega_temp
[pega:propertyfilegenerator] export.archiveName=
[pega:propertyfilegenerator] export.productName=
[pega:propertyfilegenerator] export.productVersion=
[pega:propertyfilegenerator] export.applicationVersion=
[pega:propertyfilegenerator] export.applicationName=
[pega:propertyfilegenerator] export.branchName=
[pega:propertyfilegenerator] export.branchAppContext=
[pega:propertyfilegenerator] export.async=true
[pega:propertyfilegenerator] expose.includedClasses=
[pega:propertyfilegenerator] expose.includeDescendents=true
[pega:propertyfilegenerator] expose.excludedClasses=
[pega:propertyfilegenerator] expose.excludeDescendents=true
[pega:propertyfilegenerator] expose.startKey=
[pega:propertyfilegenerator] expose.endKey=
[pega:propertyfilegenerator] expose.startDate=
[pega:propertyfilegenerator] expose.endDate=
[pega:propertyfilegenerator] expose.reindex=true
[pega:propertyfilegenerator] expose.reindexType=nonpega
[pega:propertyfilegenerator] expose.commitRate=100
[pega:propertyfilegenerator] expose.numOfThreads=1
[pega:propertyfilegenerator] expose.async=true
[pega:propertyfilegenerator] import.archive.path=
[pega:propertyfilegenerator] import.mode=import
[pega:propertyfilegenerator] import.existingInstances=skip
[pega:propertyfilegenerator] import.nofailonerror=false
[pega:propertyfilegenerator] import.commitRate=100
[pega:propertyfilegenerator] import.compileLibraries=true
[pega:propertyfilegenerator] import.allowImportWithMissingDependencies=false
[pega:propertyfilegenerator] import.preserveOrder=true
[pega:propertyfilegenerator] import.codesetName=Customer
[pega:propertyfilegenerator] import.codesetVersion=06-01-01
[pega:propertyfilegenerator] import.async=true
[pega:propertyfilegenerator] import.skipBackup=false
[pega:propertyfilegenerator] manageTrackedData.operation=
[pega:propertyfilegenerator] hotfix.operation=
[pega:propertyfilegenerator] hotfix.dlFilePath=
[pega:propertyfilegenerator] hotfix.catalogPath=
[pega:propertyfilegenerator] hotfix.bypassSchema=false
[pega:propertyfilegenerator] hotfix.force=false
[pega:propertyfilegenerator] hotfix.async=true
[pega:propertyfilegenerator] getstatus.jobID=
[pega:propertyfilegenerator] getstatus.operationName=
[pega:propertyfilegenerator] manageRestorePoints.action=
[pega:propertyfilegenerator] manageRestorePoints.restorePointName=
[pega:propertyfilegenerator] manageRestorePoints.restorePointLabel=
[pega:propertyfilegenerator] rollback.restorePointName=
[pega:propertyfilegenerator] rollback.action=SystemRollback
[pega:propertyfilegenerator] rollback.async=true
[pega:propertyfilegenerator] rollback.downloadLogToFile=true
[pega:propertyfilegenerator] updateAccessGroup.applicationName=
[pega:propertyfilegenerator] updateAccessGroup.applicationVersion=
[pega:propertyfilegenerator] updateAccessGroup.groupList=
BUILD FAILED
/var/lib/jenkins/pegaUtils/prpcServiceUtils_73/scripts/utils/prpcServiceUtilsWrapper.xml:179: java.lang.IllegalArgumentException: Invalid File Path
at com.pega.pegarules.serviceclient.Validate.notZeroLength(Validate.java:36)
at com.pega.pegarules.util.anttasks.FileUtils.validateFile(FileUtils.java:35)
at com.pega.pegarules.util.anttasks.MultiSystemPropertyFileReader.validate(MultiSystemPropertyFileReader.java:127)
at com.pega.pegarules.util.anttasks.MultiSystemPropertyFileReader.<init>(MultiSystemPropertyFileReader.java:75)
at com.pega.pegarules.util.anttasks.PropertyFileGenerator.getReader(PropertyFileGenerator.java:250)
at com.pega.pegarules.util.anttasks.PropertyFileGenerator.execute(PropertyFileGenerator.java:207)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:293)
at sun.reflect.GeneratedMethodAccessor4.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:67)
at net.sf.antcontrib.logic.IfTask.execute(IfTask.java:197)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:155)
at org.apache.tools.ant.Target.execute(Target.java:437)
at org.apache.tools.ant.Target.performTasks(Target.java:458)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1405)
at org.apache.tools.ant.Project.executeTarget(Project.java:1376)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1260)
at org.apache.tools.ant.Main.runBuild(Main.java:857)
at org.apache.tools.ant.Main.startAnt(Main.java:236)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:286)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:112)
Ant Process returned a non 0 value
Build step 'Execute shell' marked build as failure
Finished: FAILURE
Could you please help our team in this regard?
Hussain from our team is working on it.
Could you please guide him. Below is his email ID
Thanks and Regards,
Subhajit
